10-23-2015, 12:35 PM | #15 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Oh yeah? Details?
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
10-23-2015, 02:16 PM | #16 |
Drives: 2016 Red Hot 2SS M6 Join Date: May 2015
10-25-2015, 02:15 PM | #17 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
That was one of the things I looked at at GIllette yesterday. There is a LOT of room between the calipers and the 20s. I wouldn't be that concerned going down to 19s. I wouldn't be surprised to find some 18s that clear too.
--kC |
10-25-2015, 03:10 PM | #18 |
It's the one thing I *totally* forgot to look at.
10-25-2015, 04:53 PM | #19 |
10-28-2015, 12:14 PM | #20 |
Does anyone think 18" x 8" wheels would fit over the brakes? There are basically no snow tires that fit on a 19" x 8.5" :S
10-28-2015, 12:33 PM | #21 | |
Won't know until someone tries. Should be simple enough to try and fit the 18" 1LT wheels on it and "see". Just gotta wait for someone with the materials (like a dealer with a 1-2LT and an SS) to try. Like I said, on the 4 pots, there is a LOT of room between the caliper (logo side - over a fingers worth) to the back of the spokes (where proper offset comes into play) and also between the caliper (long side) to the back of the wheel (for wheel diameter - about 2.5"). --kC |
10-28-2015, 12:42 PM | #22 | |
10-30-2015, 03:18 PM | #23 |
Do you think my 1le wheels will fit they are only 3mm off from the numbers here.
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging |
10-31-2015, 11:12 PM | #24 |
Drives: 08 Accord V6/M6 / 04 Canyon Z71 Join Date: Aug 2008
This is all I could find for markings inside the polished 20" wheel.
11-01-2015, 08:56 PM | #25 | |
11-02-2015, 07:41 AM | #26 | |
--kC |
11-02-2015, 07:57 AM | #27 |
Does it matter if the centerline moves a few mm though? So you have to exactly match the centerline?
11-02-2015, 08:33 AM | #28 |
I thought the only thing to consider with offset was to make sure the inner wheel does not hit the suspension, and you could make the wheel go further out if you wanted
