05-30-2018, 10:14 PM | #1 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Help with HPTuners Active Exhaust valve control
In HPTuners I see under System > General that's there a Active Exhaust section. Has anyone messed with these to see if it changes when the valves open or close? I want to see if when it's in Track mode I can make them stay open all the time. I know I can pull the fuse for them but I would prefer to be able to put it in Stealth in the mornings when i leave then Track anytime else.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
06-05-2018, 09:16 PM | #2 |
So I changed Exhaust Valve Enabled to Disabled and it disabled them. I would change the modes between Stealth and Track and they would stay open. So it definitely affects them. I just don't know what any of the tables mean and what to change on them. I guess i'll continue logging them and messing with them and see what happens.
Here's what some of the tables look like.
06-16-2018, 09:13 PM | #3 |
Update to this. HP Tuners was updated to read all the channels for the valves so you can see what table it's using and what row and column is being used in that table. You have to be on the latest beta to see these. There should be a update next week sometime that relabels everything better.
I've tuned my track mode to be open all the time except in 8th gear so when i'm on the freeway it quiets down and reduces the slight drone I get.
06-16-2018, 10:41 PM | #4 |
I was wondering why... but you just explained in your last post. Good stuff.
07-10-2018, 09:34 AM | #5 |
Drives: 18 zl1 Join Date: Aug 2017
07-10-2018, 06:07 PM | #6 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I'm kind of confused now, you said it was in system, but I thought you had to pull the flash from the FSCM and reflash for these tables? So you would need to license the FSCM? Or is it on the PCM? I don't see it on my 2017? I think I heard something about it changed on the 2017s to where it is on the FSCM? I guess that's another way the 2017s got screwed over besides the TCM security haha
07-18-2018, 11:39 PM | #7 |
Drives: 2018 Camaro 2SS, Hyper Blue Join Date: Jun 2016
Did you figure out how the table data works the exhaust?
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback) 1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk |
07-23-2018, 12:46 PM | #8 |
I can not gain access to these tables. I am on the latest HPtuners Beta 4.1. It's not showing up under system/general?
2016 NFG 1SS A8
07-23-2018, 02:07 PM | #9 |
Maybe try reading the car again with the latest beta.
07-23-2018, 02:21 PM | #10 |
Ok...that is what it probably is. Thanks
2016 NFG 1SS A8
07-27-2018, 07:30 PM | #11 |
Have mine tuned now...thanks for the heads up!
2016 NFG 1SS A8
08-03-2018, 06:32 PM | #12 |
08-04-2018, 12:28 PM | #13 |
There is no PCM...ECM/TCM/FSCM. Yep you need to license the FSCM which is 1 credit(50.00). It's well worth it imo to have control over the NPP valve function. The exhaust sounds much better not fluctuating open and closed at different tps percentages/rpm/gear all the time. I have Touring set closed with Exhaust startup Rumble disabled and both Sport/Track set open under all conditions.
2016 NFG 1SS A8
08-04-2018, 06:15 PM | #14 | |
