02-28-2019, 07:20 AM | #71 | |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
The 4th is now gone. More functionality is put into cavity 2 and 3. Outputs 1-10 are the same.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
02-28-2019, 07:22 AM | #72 |
Still do, but the mics are now on the main connector.
02-28-2019, 07:33 AM | #73 | |
What's coming next? Cyber security to keep everyone out of any bus on the vehicle, and audio will be no different. Everything will be locked down.
02-28-2019, 10:00 AM | #74 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
I guess the 2019 and later guys...will have to go the way us early upgraders did....capture , clean up and sum up the speaker outputs using a DSP....
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
02-28-2019, 10:26 AM | #75 | |
NAV-TV could probably still do an Ethernet AVB box, but it wouldn't be cheap. There is a lot of expense and legal things to deal with for DTCP and HDCP keys.
02-28-2019, 11:36 AM | #76 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
But even to do what they did with the MOST couldn't have been cheap. Many people were complaining about the cost of the M650GM, but I get it. Easier (and cheaper) for Pac to come along and reproduce the hard work that NavTv did.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
02-28-2019, 12:01 PM | #77 | |
The DTCP keys are really expensive to deal with. Fines and legal for violating term or a simple mistake could cost bankrupt a small company. We are a fairly big company, and it is a pain for us. I think the amount of money that you got to layout is way too big, unless you are going sell hundreds of thousands of units. Just my guess. FWIW
02-28-2019, 01:34 PM | #78 | |
You: ok, I'll just digitally erase you from existence Me:
02-28-2019, 02:11 PM | #79 |
I would have assumed that you had figured it out already.
02-28-2019, 03:01 PM | #80 |
Drives: 2019 LT3 RS Convertible Join Date: Sep 2018
The secrecy made me curious yesterday.
Sorta back to the point of the thread then, looks like I'll be going after an audiocontrol or the JL fix. I recall there being a major issue with chime volume for this method. Was there ever a proper solution (other than the MOST interfaces) to get around that problem? I'm looking to replace front speakers, disconnect rear speakers and add subs. I could be happy using just the center speaker (or adding one under the dash or something) to play chimes only. I don't suppose there is a way to use something like the ax-dsp to connect to the can bus and get chimes? Sorry, I'm just starting to piece together how all these bits work now that MOST isn't an option. Last edited by SilverCamaroVert; 02-28-2019 at 03:05 PM. Reason: clarification. |
02-28-2019, 06:51 PM | #81 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Thanks for the reply. I understand there are multiple EQ's going on behind the scenes, I was referring to adding more to the user controlled 3 band on the HMI. I guess if GM doesn't ask for it, that's the final word, but that's a shame. Correct me I'm wrong, but adding a 10 band EQ on the HMI should be relatively easy during the development stage, and would not result in any additional cost per unit during production.
02-28-2019, 08:56 PM | #82 | |
The lines of code for the HMI are written by some software contract house overseas. It takes manhours and validation, but it still costs money. I’ve been called out for adding an extra 1/2cent adhesive label. That is how tight money is controlled by the car manufacturers.
02-28-2019, 09:37 PM | #83 | |
I guess I made the assumption that processing hardware has gotten so inexpensive, it could handle a few more tasks without issue. For example, I can download free graphic EQ apps for my phone to adjust my music. I didn't realize the processing power of the hardware in these automotive systems was matched that tightly to the applications. |
03-01-2019, 03:40 AM | #84 | |
Camaro. Imagine trying to do this with the equivalent of a 32 bit 400MHz pentium II processor. Yes, it’s a DSP, so it’s more efficient, but not efficient to equal your 64 bit 3GHz processor in your phone. I think your phone has a slight advantage.
