11-01-2017, 02:01 PM | #29 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Obviously ANZE will build you anything you want, it's only money.
11-01-2017, 02:08 PM | #30 | |
11-01-2017, 02:41 PM | #31 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
11-01-2017, 02:54 PM | #32 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
But the DSSV kit is nice for us guys (me) with buyer's remorse who wish they would have bought an SS w/ 1LE package!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
11-01-2017, 02:57 PM | #33 |
A base 1SS with full ZL1 1LE suspension kit (along with SS 1LE wheel/tire package and front brake kit) is probably as close as we'll ever get to a Z28!
Best 1/4 Mile: 12.24 @ 115.9 mph Last edited by vtirocz; 11-01-2017 at 03:11 PM. |
11-01-2017, 04:12 PM | #34 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
prices
http://www.camaro6.com/forums/showth...41#post9960141
Hey Guys! With SEMA now upon us, GM has announced some goodies that they will be releasing soon. They say at the time of the announcement that they became available but unfortunately that's not the case with all the parts that they have announced. Current GM stocking information is based on 11/1/17 Parts that were announced are as follows ZL1 Spec Heavy-Duty Propshaft System - 84398125 (N/A) MSRP $1200.00, MAP should be $998.40 (Subject to Change) ZL1 Spec Heavy-Duty Halfshaft System Kit - 84398126 (Back-Order) MSRP $1095.00, MAP should be $911.04 (Subject to Change) Rear Small Brake Kit - 84396515 (Available) MSRP $600.00, MAP should be $570.00 (Subject to Change) http://thatcamaropartsguy.com/rear-s...eneral-motors/ GMPP LT1 Cold Air Intake Race Air Filter - 84355716 (Future Part) MSRP $85.00, MAP should be $84.32 (Subject to Change) High-Stall Torque Converter System - 24290897 (Back-Order) MSRP $1500.00, MAP should be $1248.00 (Subject to Change) ZL1 1LE Spec Solid Rear Cradle Mounts - 84341929 (I Currently Have one in Stock, as of right now I am the only one with it in the US 11/1/17) MSRP $395.00, MAP should be $375.25 (Subject to Change) http://thatcamaropartsguy.com/zl1-1l...eneral-motors/ ZL1 1LE Spec Handling Component Suspension Upgrade Kit - 84352119 (Back-order) MSRP $1195.00, MAP should be $994.24 (Subject to Change) Includes: 1. Front ride links 2. Front handling links 3. Rear upper and lower trailing links 4. Rear knuckles 5. Replacement fasteners (where required) 6. Performance emblem 7. Install instructions ZL1 1LE Spec Multimatic Lowering & Handling Suspension Upgrade System - 84352121 (Back-Order)MSRP $5995.00, MAP should be $4987.84 (Subject to Change) Includes: 1. Front and rear coil springs 2. Front struts and rear shocks 3. Rear spring insulators 4. Replacement fasteners (where required) 5. Front stabilizer bar 6. Performance emblem 7. Install instructions They also partnered up with American Racing Headers and Weld Racing to make Headers and Drag Wheels for you drag enthusiasts. (See Manufacture Part numbers Below) Alot of things are up in the air about these items along with the accossciated part numbers, knowing GM and working for them, the part numbers may change multiple times before the release of some of the items, along with the pricing. I will do my best to keep up to date on this specific items but here you go! |
11-01-2017, 04:18 PM | #35 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
11-01-2017, 06:22 PM | #36 | |
Drives: 2020 2SS 1LE Join Date: Nov 2016
11-01-2017, 06:36 PM | #37 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
$7k over. Missed it by ‘that’ much.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-06-2017, 09:40 PM | #38 |
Drives: 1LE Join Date: Sep 2017
Currently running 18x10 front and 18x11 with R7 on my 17 1LE. Wonder how these would work with magnetic struts?
ZL1 1LE Spec Solid Rear Cradle Mounts - 84341929 (I Currently Have one in Stock, as of right now I am the only one with it in the US 11/1/17) MSRP $395.00, MAP should be $375.25 (Subject to Change) http://thatcamaropartsguy.com/zl1-1l...eneral-motors/ ZL1 1LE Spec Handling Component Suspension Upgrade Kit - 84352119 (Back-order) MSRP $1195.00, MAP should be $994.24 (Subject to Change) Includes: 1. Front ride links 2. Front handling links 3. Rear upper and lower trailing links 4. Rear knuckles 5. Replacement fasteners (where required) 6. Performance emblem 7. Install instructions |
11-07-2017, 08:38 AM | #39 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Includes: 1. Front ride links 2. Front handling links 3. Rear upper and lower trailing links 4. Rear knuckles 5. Replacement fasteners (where required) 6. Performance emblem 7. Install instructions[/QUOTE] Can this be installed on the existing shocks & springs of the 1LE? Would there be any considerable benefit in handling if one would opt for such route? |
11-07-2017, 08:58 AM | #40 | ||
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
If I was interested in this I would probably do a hard comparison between this and a set of BMR (or equivalent) links and trailing arms. I have a feeling the aftermarket solution may be a better value. |
11-20-2017, 03:48 PM | #41 |
Drives: 2016 1SS Join Date: Jun 2017
11-20-2017, 03:51 PM | #42 |
Drives: 17 SW 1LE Join Date: Jun 2017
....OUCH
