01-29-2021, 10:05 AM | #1 |
Drives: 2019 White ZLE Join Date: Aug 2019
Line lock not working
Hi, I'm at drag strip and when I set the line lock my gas pedal goes away, no throttle response at all and can do burn out, when I turn off line lock my throttle comes back on, has any one have this happen and if so how did you fix it?
01-29-2021, 10:07 AM | #2 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Has it ever worked?
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
01-29-2021, 12:18 PM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
Traction control off?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
01-29-2021, 02:00 PM | #4 |
Loves Camaros
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1! Join Date: Sep 2012
I've tried a couple of times to get mine to work, going through the steps in the book, but haven't been able to. I got to the part of mashing the brake pedal down, but it never accepts enough pressure.
Old and new, sharing space!
01-29-2021, 02:39 PM | #5 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Try this
https://m.youtube.com/watch?v=bakOzCA_2Rg Hopefully that helps Edit. Thinking about this now, iirc you have to have the shifter in first gear too being a 6 speed. |
02-15-2021, 08:15 PM | #6 |
so i think i figured it out but i need to try it some more, if you do not release the line lock before the 15 seconds is up it will go into limp mode and you will have no throttle, i was playing around with it in the stagging lanes to make sure i was doing everything right and caused it to go into limp mode, when that happen you will have no throttle at all, i ever figured out how to reset it and ruined my run that time, idk if you have to turn key off and on or go out of track mode and back in or what, if i figure it out i will report back cuz going into limp mode at the track is no fun...
02-15-2021, 09:48 PM | #7 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Are you tuned? Some tuners are disabling the assists by default.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
02-16-2021, 01:08 AM | #8 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Make sure its in drive. If its in park, you can mash the pedal till it breaks, it wont lock the front wheels |
02-16-2021, 06:45 AM | #9 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
You have to be in drive as previously stated. Mine works but I hate the steps to get there.
1. Find the singing bush 2. Summon the invisible swordsman by saying 3 chants And just maybe you don’t deactivate it when at the staging lanes in front of everyone. |
02-17-2021, 09:36 AM | #10 |
Petro-sexual
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // TooHighPSI Port Injection // FF // Katech Dual In-Tank // Soler 103 // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
02-17-2021, 10:10 AM | #11 | |
Loves Camaros
Tara
Thread Tools | |
