12-12-2020, 08:38 PM | #1 |
Drives: 2022 Camaro 2SS 1LE Join Date: Sep 2018
New Camaro, New Noises
I have a brand new 2021 1SS 1LE that I picked up Nov. 30th and I'm already having an issue. I've been driving the car every day since I got it, and am doing my best to follow the GM break in procedures - not dogging it or thrashing, varying RPM, keeping it under 4,000, etc. I mostly drive it in Sport mode, but have used it in Touring a few times. I feel like I've got a pretty good handle on how the car feels and the noises it should be making.
Well last night I was turning into my neighborhood and I heard a very sharp, distinct noise, like a sudden bang/pop, and then the car was louder. The only way I can describe it is like a hole suddenly appeared in my firewall and I was hearing more wind/road/engine noise coming from that area. Today I took a look under the hood, my first thought was the sound tube became damaged/disconnected, but it seemed fine. I also looked under the car for anything that was damaged/dragging but didn't see anything. I took it out for another drive today, and the noise is still there, and seems like it's getting worse. I usually run in Sport but switched to Touring and it's even more apparent. I've also noticed that there's some more vibration in the clutch/shifter and in the bottom of my seat. I also am detecting a sort of clicking/grinding noise that seems to be proportional to engine RPM. I'm familiar with clutch chatter in multi-plate setups but this seems somehow different/worse. My first thought is something transmission related owing to the vibration in the shifter/clutch area. The other thing I'm thinking is something exhaust related, maybe a leak up near the header or cat? It's obviously still under warranty, so I'll end up taking it to the dealer and letting them address it, but I always like to do my homework before turning my car over to someone. I'm just curious if anyone has experienced something like this. I find it helpful to be able to show up to the dealer with a list of symptoms and possible explanations. |
12-12-2020, 08:46 PM | #2 |
Do or did you have a check engine light? If yes, it might be the valve spring failure that plagues several GM V8 engines due to a bad batch of springs, see https://www.corvetteblogger.com/2020...-valve-springs.
Regardless of that, I'd take it in ASAP, the majority of engine failures occur during the first few hundred miles and that's what you have the powertrain warranty for. Good luck and hope this gets fixed soon.
12-12-2020, 09:01 PM | #3 | |
12-12-2020, 10:41 PM | #4 |
2020 Shadow Gray 2SS
I would say Valve Spring issue which is a know issue for car built in the last 6 months or so (LT1 & I think LT4's)...
Also, your 2021 has a Sound Tube??? My mid-year 2020 2SS came without one from the factory...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
12-12-2020, 10:58 PM | #5 |
Yeah, I'm starting to think its the valve spring - it would explain both the RPM rate noise and the shuddering/vibration.
The TSB calls out all engines (LT1, 2, 4, as well as some of the LT based truck engines) but specifically says cars built between June and September. But I'm sure these things can grow as more cars come to the forefront with the problem. Guess I'll be the guy to expand it to October cars. Yeah, I'm pretty sure I'm looking at the right thing... Or maybe it's some other wiring harness. |
12-13-2020, 12:22 AM | #6 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
A video of the engine running or driving might help. I would think that a valve spring breaking would cause other issues. Or at least would make a very direct noise/ sound from that head. Good luck.
12-13-2020, 05:59 AM | #7 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
If a valve went you think that would be it for the engine and it would come to a stop with all kinds of nasty sounds.
12-13-2020, 09:14 AM | #8 | |
That's why I was asking in the other thread if anyone had any warning signs before it happened. I've noticed with my issue that if I'm in Sport mode with the NPP exhasut open its very hard to hear, it's much more noticeable in Touring mode when everything else is a bit quieter. I'll try to get some video later today. |
12-13-2020, 10:54 AM | #9 | |
'20 ZL1 1LE A10,
12-13-2020, 03:25 PM | #10 |
You might also buy a valve spring tester and pull each spring and record their strength so you'll know where they are right now
'20 ZL1 1LE A10,
12-13-2020, 06:42 PM | #11 |
I did start the car up today, put it up on ramps, and also popped the hood. I'm not so sure it's valve train at this point. Almost seems like it's clutch/transmission related. It seems worse in the car than out of it, which is odd.
Its a brand new car, 2 weeks old, 400 miles on it. Its still within warranty so its the dealers problem at this point. |
12-14-2020, 08:27 AM | #12 |
I talked to the dealer this morning, they were hesitant to send a tow based on my description of the problems. We talked a bit and they finally said bring it in, if it grenades it's on them anyways, but I drove it there just fine, other than this clicking/grinding noise.
While driving I tried to pay attention and it seems like the noise/vibration mostly occurs between 1500 and 2500 RPM, approximately. I messed with the mode settings and it's way more apparent in Touring and basically non-existent in Sport mode. My working theory, now, is that its exhaust related, perhaps one of the NPP valves is stuck open or semi-open. It would explain the increase in noise, and why it's way less noticeable in Sport v. Touring modes. It would also explain the noise/vibration in that particular RPM band - it would create a flow imbalance between the sides which would manifest itself as a resonance with that peaks in the RPM band in question. I'll let you all know once the dealer calls and I find out more. |
12-14-2020, 10:24 AM | #13 |
Drives: Camaro 2020 2SS VERT Join Date: Dec 2020
There is a break in procedure for the V8??? I drove it hard since i got it. 3000 KMS on it, converted to miles 1,864. I read the warranty on it, it stated no upgrades to the drive train and no tracking it. Done and done, excet one day i hammered it on the HWY and accidentally hit the paddle shifter and shifted down and the engine revved up to 6,000 rmp.
12-14-2020, 10:47 AM | #14 |
Hope not. Mine was dyno'd a bunch of times at 400 mi, so...
'20 ZL1 1LE A10,
