08-16-2022, 02:20 PM | #29 | |||
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
https://techlink.mynetworkcontent.co...mber_20191.pdf |
08-16-2022, 03:03 PM | #30 | |
Drives: 2019 ZL1 Join Date: Mar 2019
It affects all of them.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-16-2022, 03:08 PM | #31 | |
Mic Drop. l
08-16-2022, 03:08 PM | #32 |
Drives: 2018 ZL-1 Join Date: Jan 2018
08-16-2022, 03:14 PM | #33 |
I don't think you understand, this is one reasons the pump implodes. Did you read on some peoples post where they say they saw a high spike in pressure only to see it fall well below normal? The chain tensioner has always been an issue.
08-16-2022, 04:26 PM | #34 |
I'm not going to get in a pissing contest about this with you. If you think this is the main issue with the pumps, more power to you.
However, there has been absolutely no mention of damaged cam chains or tensioners on this forum with respect to oil pump failures in the oil pump failure thread. Let me see if I understand what you think happens: The oil pump control valve fails, and oil pressure spikes, per the GM notice you posted. Then the cam chain tensioner fails some how, causing the oil pump to shit itself. There may be damage to the outside of the pump housing due to cam chain tensioner failure. I re-read the GM notice many times, and they link these three things together somewhat poorly: the oil pressure control solenoid valve failure, the cam chain tensioner, then eventual oil pump failure. I don't see the connection. Maybe, the cam chain tensioner fails somehow, which causes the oil pressure to spike, then that somehow causes the oil pump to fail internally. Is a big oil pressure spike sufficient force to crack the inner ring of the oil pump, which is the failure point inside the pump? I don't know. Maybe you could walk me through the sequence of events which cause oil pump failure. And please give me some insight into why Katech has tested all 7 versions of the GM pump, and they all break under load, seemingly without a cam chain anywhere near the test fixture Thanks. |
08-16-2022, 06:20 PM | #35 | |
08-16-2022, 06:36 PM | #36 |
There are a couple known issues with these. One is the timing chain guide/tensioner failing and lets the chain saw a hole through the back side of the oil pump. I believe that is a separate issue from the 2017-18 ZL1 oil pump failure where the internals break. There are also lifter failures and valve spring failures on some 2020 LT2's. Most of it is very low failure rates. The 2017-18 oil pump failure is probably the biggest one of all the issues but even then it's not like they are failing left and right like the LS7's were dropping valves.
2016 NFG 1SS A8
08-16-2022, 06:42 PM | #37 |
Drives: 21 ZL1 Join Date: Feb 2022
Lets clean up the facts shall we. Lets let Matt from RPM explain whats happening.
https://youtu.be/YjnvvJbesHk?t=1572 |
08-16-2022, 06:45 PM | #38 |
And here is the revised part. $136
https://www.oemgmpartscenter.com/p/C.../12686434.html |
08-16-2022, 06:57 PM | #39 | |
08-16-2022, 07:01 PM | #40 | |
08-16-2022, 07:53 PM | #41 |
Yeah and the thread is oil pump failure which what the OP posted is clearly not related to the known 17-18 failure so let’s just stop that in its tracks right now.
08-17-2022, 09:21 AM | #42 | |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
It was just a post to have an answer about problems on an oil pump.. Thé post where I got this questionned thé relation with 2017 2018 and some 2019 problems… I was searching for a thinking answer and not cockfight with the one who wanna absolutly be right… there is a fact … all the rest is supposition…that was an interesting thing to debate …and it appears clearly that some need to be more humbles |
