TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 04-28-2015, 10:15 PM   #1
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
supercharger/pulley install help
Hey guys, so my 2012 ZL1 with 10000kms on it is going in for the S/C bulletin and getting a new one put on. Thing is I just got my 2.85" pulley and solid isolator in and now I have to wait until they put my new SC on. My question is if I remove all the bolts raise the SC off the block do I need new gaskets? Or can I remove all the bolts with enough room to access all the snout bolts and just torque them back down with the same gaskets, I plan on doing is soon after the new SC is installed. Also is there fluid in the nose cone that may spill out when I remove the snout? Will the new SC have a solid isolator ? If so should I replace it with the one I ordered ? Thanks for your help guys!!
JBZL1 is offline   Reply With Quote
Old 04-29-2015, 11:51 AM   #2
96ss1664
96ss1664's Avatar
Drives: 1996 Z28/SS, 2013 ZL1
I would like to know about the gaskets myself because I see a lot of threads and a SLP procedure that just says lift front of the SC up 1" to 1.5" to remove the snout bolts. But I did read one article where it said to pull the SC and check the gaskets and replace as needed.
Make sure to torque the SC and lid to correct torque specs and sequence. The snout has no fluid in it and the new SC will have the solid coupler.
Read this thread:
http://www.camaro5.com/forums/showthread.php?t=313908
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax
ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2...
96ss1664 is offline   Reply With Quote
Old 04-29-2015, 12:14 PM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
I'll say no. The intake gaskets on the ls engines are nothing like the old felt ones from gen 1. They are thick plastic and o-ringed. Looked to me like you could use them over and over again with no issues.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
