09-26-2019, 03:36 PM | #1 |
Drives: 2016 Camaro SS Join Date: Jun 2019
Coldest temps for run flats
I have the stock run flats on my ss. They are the summer tires. How cold can it be outside before these tires get dangerous. I was hoping to get some more driving in this season but they are predicting temps in the 30s for a low next week.
09-26-2019, 03:48 PM | #2 |
Drives: 2016 Camaro SS, Garnet Red Join Date: May 2013
I drove with the stock Goodyear runflats all year round for three years until they wore out. Lowest temp I saw on the dash was 10 degs last winter. Just dont expect as much grip at low temps and drive accordingly.
Sent from my SM-G973U using Tapatalk |
09-26-2019, 05:42 PM | #3 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I personally avoided below freezing temps.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
09-26-2019, 11:10 PM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
If you read the fine print most summer tires aren't warrantied below 40 degrees. The rubber becomes hard and the tires are more at risk for impact damage from pot holes, curbs, etc. Probably the bigger risk is that the tires are more are more likely to lose traction on cold roads with dew or light moisture.
09-27-2019, 05:18 AM | #5 |
Drives: 2017 Camaro SS Join Date: Nov 2018
In my experience once the temperatures dropped below 40 the tires seemed to lose grip. I switched over to the Continental DWS 06s.
Kevin
Luceo Non Uro |
09-27-2019, 12:59 PM | #6 |
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8 Join Date: May 2018
Expect less traction at 40 degrees and do not use them at all at 20 degrees or below. In fact, don't even store them at 20 or below.
From the Camaro Owner's Manual: High performance summer tires have rubber compounds that lose flexibility and may develop surface cracks in the tread area at temperatures below 20 °F. Always store high performance summer tires indoors and at temperatures above 20 °F when not in use. If the tires have been subjected to 20 °F or less, let them warm up in a heated space to at least 40 °F for 24 hours or more before being installed or driving a vehicle on which they are installed. Do not apply heat or blow heated air directly on the tires. Always inspect tires before use. |
10-04-2019, 03:11 PM | #7 |
Drives: 2008 Corvette Join Date: Aug 2019
Are you guys referring specifically to the Goodyear Eagle F1 Asymmetric 3 summer-only run-flat tires that the new SS cars come with?
I'd like to know at what temperature it becomes noticeable that it's too cold for them. I'm talking just dry roads. My brother has a '17 Corvette GS that came with Michelin SS and he said they felt unsafe even at 50 degrees.
1983 El Camino Choo Choo SS w/1996 LT1 and 4L60E - Project Thread
1955 Bel Air Sport Coupe w/Ram Jet 350 and Tremec T56 Magnum 1957 Chevrolet 3200 pickup w/TPI and 700R4 - Build Thread 2008 Corvette 3LT Coupe, LS3/6spd, Atomic Orange, all stock |
10-04-2019, 04:14 PM | #8 |
Avoid using summer tires on temps below 40.
'16 Camaro 1SS
10-04-2019, 10:53 PM | #9 |
I did a little spirited driving this morning. It was 45 outside and I could tell that the tires were not grabbing.
