09-29-2016, 06:36 PM | #15 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
09-29-2016, 07:04 PM | #16 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
The bottom line is: GM says change it when the oil life Monitor says to. I own or have owned a few 6.2's (5) and never have changed the oil (for the 1st time) with LESS than 2500 miles, I work My Trucks and Play Hard with the Cars and NONE of them use ANY oil. Oil filters are made to collect CRAP in the oil. Let the filter do its JOB. I Can't explain why changing the oil Early creates Problems, But I sure could Explain it if the change was to a Full Synthetic at 500miles.
09-29-2016, 07:15 PM | #17 |
Drives: 2021 300 Join Date: Jan 2015
These Di Lt engines have low tension rings for better economy they will use oil more than the LS1 engines.
http://www.import-car.com/internal-e...n-diagnostics/ http://www.bgprod.com/blog/under-pre...-piston-rings/ |
09-29-2016, 07:29 PM | #18 |
Drives: 2016 camaro 1ss Join Date: Mar 2016
I was half a quart low at 5000 miles when I did my second oil change and made sure the dealer knew it. First was at 1500.
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels |
09-29-2016, 07:51 PM | #19 | |
マスタング = 遅い
09-29-2016, 07:53 PM | #20 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
I recall 1 quart per 900 mile being the threshold for consumption needing a repair.
09-29-2016, 08:53 PM | #21 |
Drives: 2017 1LE SS Join Date: May 2014
Same... also changed at 1,500. And will again every 4,000 going forward. No oil loss yet. Currently around 3,100 miles (changed to mobile 1 at the 500 mark)
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
09-29-2016, 09:20 PM | #22 |
Drives: 50th Anniversary 2SS M6 Convertible Join Date: May 2015
As someone who had to try to explain oil consumption to many customers.... Due to tolerance build up an engine can use anywhere from 0 to 1 quart in 2000 miles and be within "Standard" only when consumption exceeds 1 quart in 2000 (verified thru oil consumption test) will any attempt to correct oil consumption. FYI until around 1995 it was 1 quart per 1000 miles
2017 2SS M6 H50 Convertible 1 of 158
1100 8/05/16 | 2000 8/08/16 3000 8/10/16 | TPW 9/5/16 8/13/16 3100 8/26/16 | 3300 8/30/16 3400 8/31/16 | 3800 9/8/16 PS#2293 4B00 9/10/16 | 4200 9/13/16 5000 & 6000 9/14/16 |
09-29-2016, 10:40 PM | #23 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
These oil discussion threads are always interesting. So many different opinions on this topic but I never see any real scientific data on any of it.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
09-29-2016, 10:58 PM | #24 |
Drives: '17 2SS 50th Join Date: Sep 2016
This. Endless debate when it comes to oil... along with break-in method.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
