03-18-2019, 03:50 PM | #1 |
Drives: 2013 Camaro 2LS Join Date: Mar 2018
2LS 2.92 diff to LT 3.27 diff question
I recently swapped my 2.92 carrier for the 3.27 carrier from a LT model and I’m a bit concerned because my car feels the same. The mph did not change locations in the rpm range in 1-6th gear. I assumed my mph shift points would change but did not. Does anyone know why both diff’s have the same shift points? I feel like I wasted my money to be in the same spot.
03-18-2019, 03:56 PM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Did you tune your car to adjust to the new gears?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
03-18-2019, 08:21 PM | #3 |
No I know the speedo should be the same but it FEELS the same. like the motor revs the same as before, doesn’t go through the powerband faster than I thought. I’m getting it retuned Friday so i’ll See what my tuner says
03-18-2019, 11:39 PM | #4 | |
Drives: Miss Con Ception Join Date: Aug 2016
The speedo uses the driveshaft speed to determine MPH and miles traveled. Until you have the speedometer re-calibrated the speedometer and odometer will show higher speed/more distance than is true. You gained ~12% increase in rear wheel torque, something you should be able to notice. I don't know how Chevy tuned the trans and torque convertor for the difference, but it may be the convertor is locking sooner than it would on an LT that came with the 3.27. Your tuner may be able to change that.
2011 1SS/RS LS3 CGM
03-19-2019, 09:27 AM | #5 |
I would wait for the tune before you jump to conclusions, but also you might not feel too much of a difference off the line either, the v6s aren't that torquey until you get high into the RPM band anyway.
Tags |
2ls, differential, gears |
