11-14-2022, 06:58 PM | #29 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
11-14-2022, 07:19 PM | #30 |
I just went back and seen you edited you initial reply. So yeah now that makes more sense and I agree.
2016 NFG 1SS A8
11-14-2022, 07:34 PM | #31 |
Congratulations, Ron, I'm glad you got it done. Your car is more amazing than ever
11-14-2022, 07:40 PM | #32 |
Very impressive!! Congrats!!!
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
11-14-2022, 08:21 PM | #33 | |
Thanks, really appreciate it. Thanks man. sorry about your car, I saw your post. When your new build gets done this will be a thing of the past.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
11-14-2022, 09:15 PM | #34 |
I just checked with Elite Tuned and they are doing tuning now with the Reflex Plus controller. If you weren't aware Elite Tuned is the Vengeance Racing tuner as well as many other shops since they do a lot of remote tuning since leaving VR exclusively.
11-15-2022, 08:33 AM | #35 |
Yep, I heard that. Really the only shop I read say they wouldn't use it until it got wideband support is Joe @ Cordes performance. But he didn't elaborate why...
2016 NFG 1SS A8
11-15-2022, 09:18 AM | #36 |
Thanks for the kind words!
2018 ZL1-NFG-A10
11-15-2022, 09:28 AM | #37 | |
11-15-2022, 09:30 AM | #38 | |
11-15-2022, 09:34 AM | #39 |
There are lots using it, they can barely keep up with the orders. Mine with just my AEM wideband is all that's needed for tuning. Hopefully Mike will chime in with more explanation on the wideband tuning that I have. Matt from Nickey has tuned at least 3 with THPSI and they have several others in the works. Matt did a video about tuning the PI.
11-15-2022, 10:04 AM | #40 | |
What is being questioned is why a few shops want dedicated Wideband support for closed loop fueling @ WOT which the Holley has? This means The ECU will adjust fueling as needed based on o2 and maf data even when WOT. Up until the C8 Vette GM has always used narrowband o2 sensors and defaults to Open loop when entering PE mode(WOT). So the ECU uses a fixed set point for WOT fueling(PE). However, the ECU still relies on the MAF to adjust for air density. I believe some of the Closed loop WOT fueling advantages are easier and more accurate tuning, but we have been successfully tuning big HP GM cars for years in Open loop with no trouble. I found it odd when Cordes performance said "we won't run it until there is wideband support". I just wanted some clarification why? Perhaps Mike can chime in on that?
2016 NFG 1SS A8
11-15-2022, 10:11 AM | #41 | |
