05-27-2018, 09:35 PM | #183 | |
Drives: 2016 Vert 2SS/2018 ZL1 Vert Red Hot Join Date: Dec 2016
05-27-2018, 10:19 PM | #184 |
Just in case anyone is asking the question why my PDR screen(s) do not look like the other Camaro PDR screens, (Blue background(s), different tach showing in the video, etc) my PDR came out of a salvaged CTS-V therefor the theme overlay on it is of the Cadillac CUE system. I am looking into the ability to flash it with the Camaro software to better blend it into the MyLink theme from the Camaro line.
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar |
05-27-2018, 10:57 PM | #185 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Ben get yours done so you can help me!!! I want this soooo bad but think it is beyond my technical scope
05-28-2018, 10:15 PM | #186 |
LOL. where in MA are you?
05-28-2018, 11:17 PM | #187 |
05-29-2018, 01:17 AM | #188 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Sadly, I don't think this will work in a '16. I've wanted it since announced but, those that have done the programming can correct me if I'm wrong, the modules from the '16 are not the same as the '17 and the IO6 radio is definitely different. The lack of storage and RAM in both the radio and HMI alone likely prevents its' use for PDR. And I'm not sure if all the '17 modules can be transplanted to a '16.
05-29-2018, 01:36 AM | #189 | |
I don’t have access to a service manual from a 16 however as long as the connectors are the same and the correct wires to tap are present I think it should be able to be done. I have taken a module out of a 14 Cadillac to add HD radio, while I was able to get that to work I am working on a different solution, long story short I would assume the modules should be able to be changed as long as the connectors and wiring lines up. If you PM me your VIN I can check if the A11 radio I have had a calibration for your car. As far as the HMI I would check with Chris White / Gen5 you could also ask them on the A11 radio module programming. Sent from my iPhone using Tapatalk Pro
PRIOR CAR:
05-29-2018, 08:14 AM | #190 | |
I hack cars.
Drives: Lots ;) Join Date: May 2009
Chris White
Some uhhhh cars. Last edited by GTPprix; 05-29-2018 at 08:26 AM. |
05-29-2018, 08:30 AM | #191 | |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
05-29-2018, 09:11 AM | #192 |
I hack cars.
LOL All kidding aside you'd be surprised how many dealers ignore GM... and get screwed LOL
Chris White
Some uhhhh cars. |
06-03-2018, 05:23 PM | #193 |
Any update yet?
06-03-2018, 05:56 PM | #194 |
Sarcasm loading --------
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
06-03-2018, 11:03 PM | #195 |
06-03-2018, 11:48 PM | #196 |
Partially completed install PDF added to first post in this thread.
Ill work on it daily (as I have time) until completed.
