Old 12-19-2020, 03:44 PM   #1
zag
Drives: 2018 camaro 2 ss
Rear diff
I thought if you develop the dreaded groan in rear diff, they replace the gear oil with a special gear oil. Does anybody know what the number of the gear oil is?
THANKS
zag is offline   Reply With Quote
Old 12-19-2020, 08:57 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Quick search shows TSB #17-NA-287
From my understanding, they use the factory defined fluid from the owners manual. So it's just a drain and refill I guess?
Manual shows "Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 88900401) Add Limited Slip Additive GM Part No. (88900330)"
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 12-21-2020, 01:19 PM   #3
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Royal Purple Max Gear 75W-90 Synthetic Gear Oil is what I use and no groan.
https://royalpurpledirect.com/max-ge...etic-gear-oil/
getchapull is offline   Reply With Quote
Old 12-21-2020, 07:46 PM   #4
Nitronut
Nitronut's Avatar
Drives: Duramax, 2018 Camaro SS 1LE
I use Red Line GL-5 Gear Oil (57905) No noises here.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
Nitronut is offline   Reply With Quote
