Old 06-17-2018, 04:02 PM   #197
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Anyone find out how the microphone hooks up to the PDR?
Old 06-17-2018, 04:04 PM   #198
mbnwa
Drives: 18 NGM ZL1 1LE
Almost positive it’s built into the Camera no addition changes was required to make it work after hooking up the camera
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar
mbnwa is offline   Reply With Quote
Old 06-25-2018, 09:49 AM   #199
dunedon
dunedon's Avatar
Drives: 2018 Hot Wheels 2SS Convertible
This should be obvious but I'm hoping maybe I don't understand how warranties work
Adding the PDR, Camera, GPS and especially re-flashing components ... DEFINITELY voids the warranty right?
... If so, how much of the warrenty, just the electronics or everything? (including the body, powertrain, etc.) ...
2018 Hot Wheels SE, Convertible, V8, 2SS, A8, MRC, Nav, NPP (WDXNTP)
1100 - 28/05/18 | 2000 - 31/05/18 | 3100 - 05/06/18 | 3400 - 15/06/18
.TPW - 16/07/18 | 3800 - 16/07/18 | 4300 - 17/07/18 | 4200 - 24/07/18
5000 - 25/07/18 | 6000 - 31/07/18 | XPEL - 01/08/18 | HOME - 13/08/18
dunedon is offline   Reply With Quote
Old 06-25-2018, 11:07 AM   #200
GTPprix
I hack cars.
Drives: Lots ;)
Since we are doing the reprogramming there are no warranty implications from that end. The wiring is where things would get hairy honestly but once Gen 5 has a plug and play harness this should be far more civilized.
Chris White
Some uhhhh cars.
GTPprix is offline   Reply With Quote
Old 06-25-2018, 11:16 AM   #201
dunedon
dunedon's Avatar
<EDIT: Found my answer in another thread ... also ... TAKE MY MONEY!!>
If someone is working on a fully wired harness that will be for sale, and will be able to sell this upgrade in kit format I'm going to be even more excited
Old 07-04-2018, 10:14 AM   #202
Mike Williams
Drives: silver camaro
https://www.camaro6.com/forums/showthread.php?t=531737
Mike Williams is offline   Reply With Quote
Old 07-05-2018, 07:16 PM   #203
JaxChris
It will with proper custom programming, we've done it on other platforms without issue. Just have to be careful and do it right (and by that I mean not using other vehicles vins when programming and setting off tamper controls/blocking updates etc lol GM wasn't kidding about Global A Security in all those bulletins! )
I look forward to the harness, parts bundle and your availability to all line up (soon?).
A few other questions about what is possible through programming:
- Could a '17 HMI be transplanted to a '16?
- If it can, could the Cadillac native Spotify app co-exist with the Pandora app?
- Is HD Radio possible (especially if it requires removing SiriusXM)?
- Do you perform BCM programming as well? Could you calibrate '16 MRC controllers?
Thanks!
Old 07-11-2018, 06:58 PM   #204
mbnwa
I added HD Radio to my car it requires replacing the A11 module as the one in our cars do not have the HD Radio hardware, when changing the A11 module it will also change your SiriusXM ESN (radio id), so you will need to update it by calling SiriusXM's customer service, but you will lose any promotion time left from the factory radio id.
For reference I ordered module 84278527 105/5/6U2M it will need to be programmed to your car and or custom programmed to include the PDR if you plan to go that route.
Thanks!
PRIOR CAR:
Old 04-02-2019, 02:46 PM   #205
cnote1115
Drives: 18 ZL1 1LE HYPER BLUE & 21 F350
Did you ever get this to work?
cnote1115 is offline   Reply With Quote
Old 04-02-2019, 02:47 PM   #206
mbnwa
Can you clarify? The PDR is functional as well as the HD Radio
PRIOR CAR:
Old 04-04-2019, 02:59 PM   #207
blackdemonzl1
blackdemonzl1's Avatar
Drives: 2018 Camaro ZL1 1LE
So after reading all this I feel a bit disappointed and confused lol. I just sold my '13 ZL1 and I'm about to buy a '18 ZL1 1LE that looks absolutely beautiful but apparently it didn't have the PDR. I thought that it will be standard in a ZL1 1LE since it is a track focus car but apparently that's not the case.
blackdemonzl1 is offline   Reply With Quote
Old 04-04-2019, 03:02 PM   #208
mbnwa
Negotiate the price down enough to cover the parts and programming, add the PDR to the car, it's a little work but not that bad, in fact it's much easier to do it now that everything has been documented in terms of connections.
I use my PDR on every drive with my vert, no issues at all works as expected.
PRIOR CAR:
Old 04-05-2019, 11:04 PM   #209
blackdemonzl1
Sounds good. let's see what happens. I notice that even with everything documented there's still is a lot of confusion. And we are talking about 3k-4k for everything right?
Old 05-05-2019, 01:51 PM   #210
JD2018_ZL1
Drives: 2018 ZL1 Camaro
I made a harness. I have it all installed and had to stop and order a new screen. I thought my ZL1 had two USB ports but doesn't. I was lucky and found ONE on ebay. waiting on it to get here. My harness was made to go to the black connector of the HMI and the gray connector of the ACM a11.
I got lucky on the cost for everything. I found a ZL1 PDR for $250. Bought all the other parts from Tasca for $240 and the connectors from Mouser. The camera was on eBay for $140.
I have USB cables for my work I used. I also used a corvette camera because it has a female USB rather than a male. I have a CTS-V//ZL1 camera incase but they are identical minus the connector.
I am excited to see if I can make this work because If I can the harness is a slam dunk and I can have them made pretty easy. I also know people that could possibly make a OBD programmer to add the PDR programming needed.
Ill let everyone know once its finished.
One question I do have is what thread size is the nut to hold down the PDR.?
I forgot, I want to thank Night Owl and MBNWA. Very good work and you really deserve a lot of thanks for the effort for this. People always right these things off as not possible and that's is just not the case. I have done a lot of these types things for other brands and appreciate the work it takes. This is something I really wanted and didn't get because I wanted an 18 and didn't have a lot of choice. So thanks for figuring it out and thanks for not sealing the documents and preventing others from benefiting from your work.
JD2018_ZL1 is offline   Reply With Quote
