02-25-2017, 07:43 PM | #1 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
USB drive for MP3 music
What all has everyone been using. I bought one of the really short 32g Scandisk drives, formatted it and put all of my songs on the drive. Plugged it in and no go. The car wont recognize it. I went back and forth and maybe once out of every 6 or 7 tries it will see it and play, but the next key cycle the card wont work.
What all is every one else using that works for sure? |
02-25-2017, 08:02 PM | #2 |
I'm using a SanDisk Cruzer Fit 32gb, so nothing really sticks out to leave more room with what little is under the arm rest. FAT32 format, haven't had any issues with it.
02-25-2017, 10:19 PM | #3 |
Try reformatting it for FAT32 using Windows. Some times the formatting on the drives out of the box is not the most compatible. Either that or you have USB port issues.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-25-2017, 10:38 PM | #4 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
2 tb HDD. no issues what so ever.
02-26-2017, 11:24 AM | #5 |
I already formatted it, that was the first thing I did to get rid of the Sandisk encryption stuff they give you and still no go. The other stick style drive is working just fine though.
02-26-2017, 11:29 AM | #6 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
03-02-2017, 08:01 AM | #7 |
Drives: 2010 Camaro RS Join Date: Nov 2015
I had a problem with the first SanDisk mini cruiser that I tried with FAT32 formatting. It turned out that it was not compatible with USB 3. You have to get the USB 2 version.
USB Support If equipped, the USB connector is in the front of the center console, and uses the USB 2.0 standard. |
03-02-2017, 08:18 AM | #8 | |
03-02-2017, 09:29 AM | #9 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
I'm using a 128GB PNY flash drive, right out of the package. I don't remember the model or the specs on it. I did not format it, and it works just fine.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
03-02-2017, 01:03 PM | #10 | |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
Been in the car since last April. Holds a $hit load of music. Can barely see it when you open the console. No issues with it at all.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
03-03-2017, 08:33 AM | #11 |
Well I have now found it not working with either of the drives I have, at least not at start up. I can go thru the DIC down the road and the drive will show up and work. Then after the key cycle it wont show up next time.
03-03-2017, 08:50 AM | #12 |
Drives: 2016 Camaro SS Join Date: Feb 2017
Please allow a stupid question. Can you just copy your itunes folder from your computer, to the jump drive, and MyLink will recognize it and allow you to play the music?
03-05-2017, 12:27 PM | #13 |
No, has to be in a mp3 format and or maybe a windows media format.
03-05-2017, 12:49 PM | #14 | ||
Now as for copy the iTunes library straight to the stick, not sure. iTunes has a convoluted file structure by default. There's a guy on this forum who built a program specially to take your iTunes playlists and extract them to a USB stick. It's called CarPlaylist. Give that a shot.
