01-08-2021, 07:32 PM | #1 |
'21 ZLE A10 mode button actions
The mode button will change the shifting algorithm instantaneously when depressed. The A10 goes into full party mode in sport or track along with steering effort increase. My '17 ZL1 A10 does not do this with the mode button. This may be old news but it was surprising to me when I was cruising down the interstate at 78mph and depressed the mode button and the transmission immediately downshifted with accompanying rpm increase. Does the A10 in the newer non-ZLE cars do this or retain the "performance shifting algorithm" once the car detects aggressive behavior not related to the mode button?
01-08-2021, 07:54 PM | #2 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
01-08-2021, 08:36 PM | #3 | |
Drives: 18 zl1 Join Date: Aug 2017
I use this to slow down on off ramps often. |
01-08-2021, 11:10 PM | #4 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
All you need to do is tap the gas about half way and let go of gas pedal. This puts you in PAS mode.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-09-2021, 01:30 AM | #5 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
What do you mean by "party mode?" Like you're switching to sport/track and it goes into performance shift? Or are you just talking about it downshifting when you change modes to prepare for more spirited driving? If it's the former then my '19 non 1le didn't do that. If it's the latter then yes switching modes will cause the car to downshift and adjust the steering setting to match the mode (which can be disabled in vehicle settings).
As far as I'm aware performance shift can only be activated as you said, through aggressive driving. If it's activating for you on your '21 by merely switching modes then that's probably a newer feature. However, downshifting and tightening steering when changing modes is not. |
01-09-2021, 07:03 AM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Mine does on my 2021. If I'm in touring mode and cruising when I change to sport or track, it will immediately drop down a few gears and the exhaust will start burbling. Its not the same as performance shifting exactly because I don't think it drops down the lowest gear available, but it will drop just a few gears and hold it there for a bit. If you don't do anything after about 5-7 seconds, it will upshift again to whatever gear needed for your cruising speed.
01-09-2021, 08:31 AM | #7 |
I mean all of the actions I described occur when you depress the mode button... no paddles touched. "Party mode" means it's ready to rumble and the car is ready for track action or aggressive driving.
01-09-2021, 09:02 AM | #8 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
This changed between 2018 and 2019. My 2018 ZL1 A10 doesn't do it and my friends 2019 ZL1 1LE A10 will do aggressive downshift and exhaust pops in Sport or Track (just driving around the neighborhood). It's pretty cool.
01-09-2021, 09:32 AM | #9 |
Thank you Al Oppenheiser!
Performance Shift Management
Enabled in Sport or Track mode while the car is in D. Triggered with either throttle input past the kickdown switch or with sufficiently hard cornering at speed. The downshift the OP saw on the highway was likely caused by a change to Track mode, which does change the default shift points. |
01-09-2021, 11:06 AM | #10 |
Drives: '21 ZL1 A10 Convertible Join Date: Sep 2015
My ‘21 ZL1 Convertible downshifts like this when changing modes, too. Also, I’m surprised at how low of a gear the trans will select when holding down the left paddle. First time I tried it, it selected a much lower gear than I expected and the rpm’s shot up near 6K. I wasn’t going very fast at the time and figured it would probably drop to second gear, but it felt like first. Woke me up, that’s for sure!
01-09-2021, 11:18 AM | #11 |
The ZL1 1LE A10 and ZL1 A10 have different calibrations. The ZL1 1LE A10 is more aggressive.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-09-2021, 11:37 AM | #12 |
https://techlink.mynetworkcontent.co...March_2019.pdf
The 2019 Camaro ZL1 1LE now offers an available 10-speed 10L90 automatic transmission (RPO MGL). Unique calibrations were developed for the transmission as well as the Electronic -Limited Slip Differential (eLSD) and Performance Traction Management (PTM) system on the ZL1 1LE model.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-09-2021, 01:40 PM | #13 |
What the OP is talking about is normal for all ZL1s, possibly after 2018 according to some. Maybe the 1LE had a more aggressive programming in 2019 than the standard ZL1 but no one knows for sure if all ZL1s have the same programming now. I just know that my 2021 ZL1 does exactly what the OP is talking about in his 2021 1LE.
01-09-2021, 03:45 PM | #14 | |
🔺22 RS E TRON GT
🔺21 Model S Plaid |
