![]() Drives: 2018 Camaro ZL1 Join Date: Oct 2020
Is black smoke normal?
Well finally reached break-in mileage and took the car to ventura and did some spirited driving on the highway as well as some side roads, buddy that I was driving with in a GT350 (i know i know
Currently looking for another A10 ZL1
2018 ZL1 A10 Silver Ice Metallic; Mamo Throttle Body V2, FabTech CAI, Borla Catback Exhaust, M2W Switch - TOTALED 2000 Trans Am Arctic White |
![]() Drives: 19 ZL1 Join Date: Jan 2019
Yes, more obvious under WOT.
I notice it even more when traction control kicks in. Pretty sure they keep these engines on the rich side when under boost. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
normal for a little puff as these things run pretty rich...nothing to worry about. If you did it more than once, the smoke would likely be less.
'21 ZLE A10 Wild Cherry PDR
Probably a stupid question, but why would GM tune the car to run so rich?
fuel has a cooling effect in the cylinder so richer is cooler with less tendency towards damaging detonation. This is especially true in supercharged applications because of the heat generated by greater cylinder pressure.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
The engines are tuned pig rich to keep from blowing up. If it runs too lean then you get engine damage and or failure.
#7 | |
![]() Drives: 2019 ZL1 Join Date: Mar 2019
Be very careful with this, as puffs of smoke may not be simply from running rich. This is a very common sign of detonation. Puffs would be bursts of black/greyish smoke. Common black smoke from running rich doesnt usually happen in puffs, unless its happening immediately going full throttle. If the puffs are under load and at WOT its very possible its detonation. |
#8 |
Coupe Newbie
Drives: 2017 Mosaic Black Metallic ZL1 Join Date: Jul 2011
This and the computer is also programmed to dump more fuel to cool the catalytic converters. It referred to as cat over-temp protection or COT.
#9 |
Thank you Al Oppenheiser!
#10 |
![]() Drives: '20 ZL1 1LE Shadow Grey Metallic Join Date: Jun 2020
Black smoke normal, blue smoke death
OEM short block
HPE custom cam, valve train, and heads FII blower spacer plates & thermal reduction blanket Kong ported blower/snout NW 103mm ported TB Griptec snout pulley ( 2.4) MMS catch can, mild DSX low side pump Kooks Long tubes and Hi-flow cats Custom heat exchangers, RotoFab Remote tuned/ no dyno # yet Tires: Street - Michelin Pilot Sport 4S; Track - Goodyear Eagle F1 Supercar 3R |
#11 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 8.00/3.25, Mast Motorsports Black Label LT1 heads, CamMotion custom blower cam, Katech VVT & AFM delete covers, Rotofab Big Gulp, Katech 103mm TB, DW400 in tank pump w/JMS, Johnson 2110R lifters, GPI forged pistons & rods, LPE +52 injectors, LPE BB HPFP, AWE Touring CB, GForce 3.5” DS, GForce Outlaw axles, 2” ceramic coated Dynatech headers, MM Wild CC, LPE check valve, everything BMR makes, OEM 1LE wheels (street), Forgestar D5 bead locks (track)
2019 Toyota Sequoia Limited 4WD (daily driver) 2018 Alfa Romeo Giulia Ti Sport Q4 (hers) |
#12 |
And no or high flow cats equal lots of black smoke
OEM short block
#13 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Yes^^^
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#14 |
![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
That may be the generic answer, but I can tell you that we had two Hellcat's for over 2 years and one never puffed smoke, the other always did on hard acceleration and I doubt the tuning was any different between the two. Most of the Hellcat videos I've seen rarely ever puff any smoke. I've seen a lot of ZL1s online that seem to puff black smoke so I know its apples and oranges comparing a Hellcat to ZL1 but both are similar engine configurations, the only major difference being that the ZL1 is direct injection. Quite frankly, performance car or not, I think its embarrassing to have a car puffing smoke on hard acceleration. I haven't noticed mine doing it, I've seen a little smoke once or twice in the rear view, maybe its doing it more often than I think but I haven't been following my car while someone else was driving it.
2021 Camaro ZL1 - Red Hot A10 - Vengeance Racing Stage III - 678whp SAE/697whp STD on pump 93
Thread Tools | |
