06-12-2020, 03:16 PM | #1 |
Drives: 2017 2SS M6 FIFTY Join Date: Sep 2019
Trans and Diff fluid change: car needs to be leveled?
Is it mandatory that the vehicle stays leveled horizontally when changing transmission or differential fluids?
I am planning to do these myself for the first time tomorrow and have heard people say that if you just raise the front/back, you risk not fully draining the old fluid. Is this true or am I okay raising just the front/back wheels up? Thanks in advance! |
06-12-2020, 06:43 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
As level a surface you can get is best.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
06-12-2020, 10:27 PM | #3 |
06-13-2020, 07:06 AM | #4 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
You can probably get away with lifting the rear for the diff, but any angle will make it hard to fill the trans to the correct level.
06-15-2020, 11:05 PM | #5 | |
For servicing my trans/diff, I pull the car up on race ramps and then put the rear on stands.
2017 HBM SS 1LE
06-16-2020, 01:30 PM | #6 |
The easiest way to get the car close to level, while allowing room to work under, is to use race ramps on a mild decline. To change the rear fluid, set the ramps up at the rear of the car, backing down an decline while backing up the ramps. Do the reverse for the front of the car for transmission fluid.
06-16-2020, 08:26 PM | #7 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
[QUOTE=MatthewAMEL;10811448]For servicing my trans/diff, I pull the car up on race ramps and then put the rear on stands.[/QUOTE
Do you use wheel chocks behind the front wheels on the race ramps while you jack the rear up for the jack stands? |
06-16-2020, 08:58 PM | #8 | |
Drives: 2016 2SS Convertible Join Date: May 2012
09-06-2020, 12:19 PM | #9 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
I put the back on ramps, and then jacked the front up to level it out.
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
09-06-2020, 01:22 PM | #10 |
2020 Shadow Gray 2SS
I usually just put mine on the Homer buckets...
I keed, I keed... As Paul Harvey would say... "And now for the rest of the story.."
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
10-20-2020, 07:49 PM | #11 | |
Drives: 17 2SS 6sp Join Date: Jun 2020
Changing my diff fluid next week and would be nice to get the car level |
