01-08-2019, 11:54 AM | #1 |
Drives: 2019 ZL1 Camaro Join Date: Oct 2016
SS 1LE And ZL1 Wheel Specs
Are the ZL1 wheel specs identical with the SS 1LE wheel specs?
Back spacing and wheel well clearances the same? If so, you can run the 295/30/20 on the front of a ZL1 as other posts have mentioned? Apparently, this size tire would fit on a SS 1LE up front with stock rims? Thanks, Tyrolblue67 |
01-08-2019, 12:38 PM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Short answer is yes, SS 1LE and ZL1 have same wheel diameter, width, and offset. I'd assume a 295/30/20 can possibly fit depending on the actual size of the tire (dimensions aren't always exactly those numbers), but it'll really depend on which tire is specifically chosen.
2017 SS 1LE.
01-08-2019, 06:13 PM | #3 |
Drives: 2017 Camaro 1LE Join Date: May 2016
Im running 295/30/20 Michelin PS4S's on my stock SS 1LE wheels with no problem.
ZL1's have wider front fenders so that allows for more room outboard, I don't know if the wheels specs are the same with SS 1LE and ZL1.
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS |
01-08-2019, 09:47 PM | #4 |
Drives: 2018 ZL1 Join Date: Jul 2017
295/30/20 Michelin Super Sports fit fine on my 18 ZL1. Car is all stock.
Mark E.
2018 ZL1 NGM A10 87 Grand National. Modified Hot Rod for sale *SOLD* 87 Grand National. Stock 65 Olds Vista Cruiser wagon Grand National motor/tran 66 Bronco Rockbuggy 2006 Dodge 2500 4x4 Cummins 6 speed |
01-09-2019, 08:00 AM | #5 |
Thanks!
Thread Tools | |
