Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 06-05-2017, 11:36 AM   #1
FargoZL1
Drives: 2013 ZL1 Convertible
Will this address the supercharger rattle issue?
Guys/Galls:
I have a 2013 with 10,000 miles and the original supercharger (no problems yet). Will this upgrade from supercharges online address the rattle/bearing issue while allowing for pulley upgrades?
http://www.gm-efi.com/news/easy-lsa-...argers-online/
FargoZL1 is offline   Reply With Quote
Old 06-05-2017, 02:41 PM   #2
BEECHFRONT
BEECHFRONT's Avatar
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS
Yes, But depending on the pulley you will need different belt and a tune and possibly injectors.
What is the price?
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
2019 HELLCAT REDEYE WB
69-Z28, LSA SWAP, T56 MAGNUM
71-CHEVELLE SS, 496 STROKER TH400
BEECHFRONT is offline   Reply With Quote
Old 06-05-2017, 06:00 PM   #3
FargoZL1
$689 on manufacturers site.
Old 06-05-2017, 07:51 PM   #4
scdrj
scdrj's Avatar
Drives: 2014 ZL-1
And you still have to install it. If I were going to have to install it, I would do this:https://innovatorswest.com/1001-Blower-Pulley.html With this: http://www.ebay.com/itm/LSA-Supercha...-/192114633188 And this belt: http://www.ebay.com/itm/Gates-K08064...iRr_hg&vxp=mtr
While you will have to take the snout to a machine shop to have the old pulley press off, and the new one pressed on, you will merely need a $7.50 tube of Ultra Grey.
You will not need a tune provided "nothing" else is done to your car. Anything else, and you will require injectors. And that will require a tune, and definitely void the motor warranty. Technically the pulley and coupler will, but I doubt most would ever know it had been done.
BTW, most belt charts call for a 10mm bigger belt, but I have found this to fit best.
scdrj is offline   Reply With Quote
Old 06-05-2017, 08:43 PM   #5
BEECHFRONT
BEECHFRONT's Avatar
So your suggesting he goes with a 18% pulley and he does not need a tune?
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
Old 06-05-2017, 08:50 PM   #6
FargoZL1
So far I have deleted muffler and a rotors.
Old 06-05-2017, 09:58 PM   #7
FargoZL1
Sorry. Rotofab. Big fingers, tiny keyboard...
Old 06-05-2017, 10:13 PM   #8
scdrj
scdrj's Avatar
Drives: 2014 ZL-1
Yes, even though folks here say no. The convention here is that 10% is the limit. While this would vary from car to car, and more over climate, I have found it conservative. A stock tuned ECU will not allow a 2.55" upper to damage your engine. I've done the same with a 9.1 lower. Also used a roto-fab with it for about 18 months, and about 75 passes on an 1/8 mile track. Now this, I would not recommend.
Old 06-05-2017, 10:15 PM   #9
scdrj
scdrj's Avatar
Drives: 2014 ZL-1
Originally Posted by FargoZL1 View Post
So far I have deleted muffler and a roto-fab.
No mods means no mods. It does not mean you can not do the above, but you will need injectors, and then you will need a tune.
Old 06-05-2017, 10:55 PM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Interesting..
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 06-08-2017, 04:30 PM   #11
BlownChevy
Drives: 2015 1SS RS 1LE
I would not suggest that isolator. The packaged offered is great for someone that wants the ease of doing it in their garage and does not have the time or desire to chase down a shop to do it for them.
BlownChevy is offline   Reply With Quote
Old 06-08-2017, 06:20 PM   #12
scdrj
scdrj's Avatar
Drives: 2014 ZL-1
If they do not have the relatively little time required to find someone to R&R the pulley, they sure as hell are not going to like all the time and effort required to R&R that snout. To say nothing of the extra time it took to earn the additional ~$550 to pay for the package.
But on a more enlightening note, what do you not like about that isolator?
