04-13-2019, 02:33 PM | #15 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
You can always add the Borla "mid-pipe" muffler to your car as well.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
04-14-2019, 02:50 AM | #16 |
Drives: 2017 2LT RS Join Date: Nov 2018
04-15-2019, 06:59 AM | #17 | |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Sounds like you just want to have an aftermarket muffler just to have one. If you remove the suitcase, it will get significantly louder, regardless of what new setup you have. To put it in perspective to what sound difference you can expect. I had a muffler delete with a catless dp and it was borderline un driveable and shook my entire house on a cold start. I put the stock suitcase back on and I can barely hear the cold start from my bedroom now. Almost silent when cruising. My opinion here is if you don't want a louder exhaust, you'll be wasting a lot of your money. It will sound "better," I guess? But it will be primarily louder. I will likely go with a mid-pipe as STM mentioned because I do like my loud exhaust but not the drone from a straight pipe setup.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
04-15-2019, 09:03 AM | #18 | |
04-15-2019, 12:47 PM | #19 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
If your running catless find an axle-back with a muffler or add a resonator somewhere. I've had the flowmaster for years it is loud and if your catless it will be very droney.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
04-15-2019, 01:19 PM | #20 |
04-15-2019, 05:15 PM | #21 | |
Drives: 16 1SS 6mn npp Join Date: Feb 2016
https://youtu.be/PG4XgFuSEYw https://youtu.be/uvEQ1rrg4Eg |
04-16-2019, 01:43 AM | #22 | |
04-16-2019, 02:43 PM | #23 |
I have a MRT v2 I took off but sounded pretty good. I have a quad Mishi SS exhaust on now with a flo pro twister resonator. Both attached to a hi flow cat. It's got a good deep idle, but still gets loud when you send it. Drone is still there but very limited.
04-17-2019, 10:18 AM | #24 |
Drives: 2010 tbd Join Date: Mar 2009
04-22-2019, 08:28 PM | #25 |
Drives: 18 Camaro LS M6 Join Date: Apr 2019
looking for a less raspy interior experience. Has anyone tried a bullet style glass or mesh pack in the mid pipe? I am finding mixed reviews of other cars.
04-22-2019, 11:03 PM | #26 |
603 Camaros
Without a resonator glass packs will drone to high heaven and back.
04-23-2019, 07:40 PM | #27 |
Agreed A muffler would be the way to go. Believe it or not this is the configuration of my past MB C300, muffler up front, resonators in the back. It was super quiet.
I found this and wondering if it stands to reason, Would Borla's mid-muffler installed on the stock system, not produce a the best mute and performance offered anywhere? I haven't had a look under there yet, but I am assuming there is space in the mid section somewhere. If it seems feasible, pros and cons welcome,, I would be willing to test it. My muffler shop guy wants some user community advise to work with. Thanks. https://www.borla.com/products/camar...rt__60624.html |
04-24-2019, 12:33 PM | #28 |
That's a 5" dia. resonator tucked under mine.
The other guy that did a mid muffler used a 1 in, out type at the y section I believe. Not sure what brand |
