03-09-2018, 08:09 AM | #1 |
Drives: Bone stock silver Camaro 2ss Join Date: Feb 2017
95mm BBK TB
First time poster here! just wondering what the consensus is on the 95 mm BBk TB but I haven't seen enough feedback to decide if I should just stick with the stock one. Thanks in advance
03-09-2018, 08:53 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Nw 102mm tb and be done with it
Sent from my SM-N950U using Tapatalk |
03-09-2018, 11:32 AM | #3 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Its a good TB. It was my first TB upgrade with a noticeable increase response on the throttle. Would buy from them again.
03-09-2018, 02:05 PM | #4 |
Ordered it, should be here middle of next week and will be posting about it once I put it on
03-14-2018, 09:01 AM | #5 |
It got here yesterday and immediately put it on, noticed that it surged as everybody else was saying and it sounds like I have a leak while I'm driving. Saw on another thread that the blade may be off so I'll try and see if its off and try to figure it out. If not then I'll just return it.
03-14-2018, 09:31 AM | #6 | |
Check all hoses and connections... otherwise, yes - return it... but perhaps don't give up on it. Maybe just a bad unit. It happens... |
03-15-2018, 09:45 AM | #7 |
I took it off and reinstalled it, still giving me the same problems, I'm assuming I just need it tuned to get rid of the surge problem but the I can still hear the leak while driving. On closer inspection it looks like there is a small gap between the body and my intake? Never seen that problem occur to anyone else.
03-15-2018, 01:10 PM | #8 | |
03-15-2018, 04:17 PM | #9 |
Drives: 2018 SS Join Date: Jul 2017
would a 102 mm be to much for a non supercharged or non modded ls3
03-15-2018, 04:48 PM | #10 |
Unless you are swapping your stock intake manifold (92mm opening), its a waste of money. Id stick with a 95mm. You can port your existing to 102mm, or buy a FAST unit if you are going with a102mm BBK. You will need a tune.
Not sure how much you'd gain with a full 102mm set up. Your air box/CAI opening is also a factor. |
03-15-2018, 05:00 PM | #11 |
For reference, the stock TB is 90mm.
03-16-2018, 08:56 AM | #12 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Wish I had seen before you bought, the BBK throttle bodies were noted to be with the same exact problems you noted years ago and avoided by members on here, getting one that worked ok was a low chance crap shoot thus their lack of popularity.
Tags |
throttle body |
