07-17-2019, 05:41 PM | #1 |
Drives: 2018 Camaro ZL1 Auto Join Date: Jun 2019
A10 cold start putting in to D
So its hard to explain but whenever I start up my car in the morning and once I put in to D, the car stomps. It feels similar when you let go clutch when the car is in gear(it stomps with motor shut off).
Anyone has this issue? |
07-17-2019, 06:34 PM | #2 |
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
2019 ZL1 1LE A10. I have not experienced that. Shifts into drive smoothly. How soon after starting the car are you shifting into D?
07-17-2019, 06:39 PM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I've only experienced this after I reverse into a parking spot.
This issue has been around and talked about a lot. Im uncertain if anything was found out. |
07-17-2019, 06:51 PM | #4 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
07-17-2019, 06:59 PM | #5 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
That's a serious trans problem, causing it to lurch forward too? If so that's dangerous. Take it in for warranty repair asap.
And what does "stomps" mean i this context? Not a word I've heard used to describe this. |
07-17-2019, 07:01 PM | #6 |
Drives: 2018 ZL1 Mosaic Black A10 Join Date: Jun 2018
2018 ZL1 A10 and I always let in warm up a couple of minutes and have never had an issue.
07-17-2019, 07:12 PM | #7 |
Thank you Al Oppenheiser!
OP’s comments imply the car is stalling. In which case, that may be TC lockup at idle when shifting to drive.
Suggestion: If it’s intermittent, then get it on video first before taking it to the dealer for warranty repair. Show the vid to the service advisor. |
07-17-2019, 09:33 PM | #8 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
I think what he's talking about is that the car shifts hard going from park to drive. Sometimes an automatic will do this is you shift too soon after start up. My advice is to watch the gauges, when they regulate and set, then shift, this only takes a few seconds.
07-17-2019, 10:02 PM | #9 |
Poor A8 got quite some flak for the same thing... if the car doesn't move and it's only the trans that gives a hard shift noise when first shifting to D in the morning, I wouldn't sweat it. Does the same thing happen with P-> D and R -> D, and if the latter, does waiting a little longer after stopping and before shifting to D reduce the "stomping"? (I'm not entirely sure if I understand the word here either, by the way.)
07-17-2019, 10:35 PM | #10 |
07-17-2019, 10:54 PM | #11 |
07-17-2019, 10:55 PM | #12 | |
07-18-2019, 07:55 AM | #13 |
When I put my car in drive after a cold start, occasionally I feel what I think you're describing, which is the car kind of "hunches" down in the back. What mine is doing, if it's the same as yours, is normal. Just the car loading up, cold start elevated idle plays a part in that I believe.
Now if it's jerking forward, as in the tires actually turn some amount, then that's bad news bears. |
07-18-2019, 09:12 AM | #14 | |
