Old 04-13-2019, 10:41 PM   #113
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
I know some of you don't care or like using a drain valve (i.e. Fumoto) but I've been using them since the mid 80's and here's why.
Back then the oil change was every 3k miles...my Toyota truck had 245k miles when I gave it to my brother, and I changed my oil and filter every 3k...that would have been a lot of removing and torquing of the drain plug.
I noticed with the amount of unscrewing the drain plug and torquing it tight again and again, the threads on the oil pan was getting pretty bad.
At about 100k I put on a Fumoto valve, and have never looked back.
Now, I use the Fumoto because of the same reason above, but also for:
Ease of draining the oil, remove the locking pin, flip the lever out comes the oil.
I connect a tube to the end of the valve to have the oil directed into the oil pan hole, with no mess.
This valve also allows me the opportunity to take samples for BlackStone to get my oil analyzed without a mess and trying not to over-fill the sample bottle.
I can take some oil at the beginning, mid and end of the drain without any mess...much easier to start and stop a pour of 10qts of oil.
I don't have to get new gaskets or torque the drain plug, just close the valve, place lock on it and done.
Now as for the oil filter, I have never heard of torquing the oil filter tight. On canister top fill oil filters, I can see torquing the cover nut, but never on a twist on oil filter.
Most filters will have instructions that say:
Spin on filter until contact, then tighten 3/4 of a turn by hand.
I learned with my Toyota truck you can over tighten the oil filter and tear the rubber gasket, which in turn will cause the filter to leak at the gasket contact point.
Seems like the oil change on the SS will be almost as easy as on my Silverado I had, just getting it on the ramps may be a problem.
I'll have to make wooden steps for the ramps with some 2x6 boards I guess.
Happy Motoring!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 04-14-2019, 12:35 AM   #114
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I wrote about using oil valves here about 2 1/2 years ago. Fumoto works great, a bit more elegant solution is the Stahlbus valve.
https://www.stahlbus-us.com/oil-drain-valve/
Old 04-14-2019, 03:00 PM   #115
OVRKLL
Thanks, I never heard of this type.
The Stahlbus is much nicer and clean looking with the cap, but I like the functionality of the Fumoto better, where you have control of the flow of oil coming out...open all the way, half-way or quarter-way etc.
Now if this was an area that could be seen without having to go under the car, I would probably get the Stahlbus.
Old 06-02-2019, 12:24 PM   #116
Marko
Marko's Avatar
Drives: Camaro
I know it’s been mentioned. I searched and I couldn’t find the exact question.
I only drive my 2018 Camaro 2SS 3k miles a year. So, should I change the oil just once a year. It always stays clean. I use Mobil 1 5W30 Full Synthetic oil.
Marko is offline   Reply With Quote
Old 06-02-2019, 12:29 PM   #117
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
you have full control over the oil flow with the Stahlbus by simply pushing it in, it starts to flow, let it out a little bit and it stops. I’ve never spilled a drop in pulling out oil samples or small amounts…
Old 06-02-2019, 01:41 PM   #118
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
Once a year is correct.
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
Old 07-05-2019, 11:00 AM   #119
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Originally Posted by breakskeet View Post
Oil filter torque spec for my Corvette Z06 is 22 lb.ft. Most likely it it the same for the Camaro.
Pardon my ignorance, is that the same 6.2L engine as in the Camaro SS?
Emoto is offline   Reply With Quote
Old 07-05-2019, 11:38 AM   #120
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
+1 I love mine.
Makes taking samples for Blackstone easy peasy!
Old 07-06-2019, 04:33 AM   #121
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Originally Posted by R3DLT1 View Post
You drained a little over 10qt?! WTF...
I know. Does he have an oil drain pan marked with the amount of oil drained?
The Specialist is offline   Reply With Quote
Old 07-06-2019, 04:45 AM   #122
The Specialist
Rhino ramps are Ok for a Base Camaro. They won't work for a 1LE with Splitter.
I purchased the 10" high Race Ramps. You can drive right up on them without any assistant having to watch.
Lol.
Old 07-06-2019, 06:42 AM   #123
Emoto
Sure, why not?
Emoto's Avatar
Lol.
I lean a mirror against a concrete block, angled so I can see my wheel as it goes up onto the ramp. The mirror is about 1' x 3' and meant to hang on the wall or the back of a door. Not expensive to buy, but I had one kicking around.
Similar to this: https://www.walmart.com/ip/Mainstays...ches/293046439
Old 07-06-2019, 06:34 PM   #124
Emoto
Sure, why not?
Emoto's Avatar
It just so happened that I needed to change my oil today, so here is a picture of what you can see in the mirror from the driver's seat, when you position the mirror correctly. You can watch your wheel go up and know exactly where you are on the ramp. This makes it much safer, IMHO. Not all of us have someone around all the time to guide us up.
Old 07-10-2019, 12:16 PM   #125
Max Droptop
Max Droptop's Avatar
Drives: 2019 Camaro SS Convertible
What is the size of the oil drain plug on 6.2?
Stahlbus only lists up to 2015. Probably same but need to make sure.
1969 Z-28 302CI/4-Speed
1989 Camaro 350CI/ AT
2013 RS Convertible V6/AT
2016 SS 376CI/AT
Max Droptop is offline   Reply With Quote
Old 07-11-2019, 02:21 PM   #126
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
The size (M12 x 1.75) is what matters. The 09-15 is the same as Gen 6.
viurniel is offline   Reply With Quote
