04-23-2018, 04:12 PM | #1 |
Drives: Camaro Join Date: May 2016
Another Oil/Filter Question
Is this the right filter for the 2018 Camaro SS LT1? And do any of you guys use Valvoline or other name brands just so it’s Dexos rated ?
Sent from my iPhone using Tapatalk |
04-23-2018, 04:52 PM | #2 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
You can use that. The technically correct filter is the regular PF-64, but you can use the UPF-64R instead. Oil is up to you, so long as its Dexos certified. My choice would be Mobil 1 or Pennzoil Platinum. Save your receipts too in the worst case event if you need warranty engine work, that way you have proof of using a Dexos approved oil.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
04-23-2018, 04:56 PM | #3 | |
Just found this thread https://www.corvetteforum.com/forums...lter-pics.html |
04-23-2018, 05:05 PM | #4 |
My Bad for posting this in the wrong forum but my Tapatalk wasn’t working right.
Can a moderator move this ? Thanks |
04-23-2018, 05:43 PM | #5 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
PF64 is the AC Delco professional line. On yours, R stands for the race version. ;-)
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-23-2018, 06:10 PM | #6 |
You guys wouldn’t believe how hard it is to find the regular PF64 filter. In N/W Indiana. Wtf.
04-23-2018, 06:12 PM | #7 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
04-23-2018, 06:24 PM | #8 |
Most places carry AC Delco. Just not PF64
04-23-2018, 06:39 PM | #9 | |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Use the filter you posted. I ran the 48 version on my old car and on my truck and they are a much better filter than the regular version Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
04-23-2018, 06:39 PM | #10 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
https://www.amazon.com/ACDelco-PF64-...f64+oil+filter
https://www.amazon.com/ACDelco-UPF64..._&dpSrc=detail I just run the OEM Pf64 filter with the OEM Mobil1 5w-30 @ 3k mile intervals. Oil changes cost me 50 bucks through amazon.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! Last edited by soloknight6; 04-23-2018 at 06:55 PM. |
04-23-2018, 06:41 PM | #11 |
Drives: A10 LT4 Join Date: Aug 2016
I could only find the R version...was told it was a supersede from the dealership??
04-23-2018, 06:44 PM | #12 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Wix is fine. WL10290
2012 Yukon XL Denali w/ 6.2 AWD |
04-23-2018, 07:41 PM | #13 |
Thanks guys. Think I’m gonna use the 64R filter.
04-23-2018, 07:52 PM | #14 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I'd be cautious of using the UPF64R without first digging into the specs and understanding if it's an overall improvement. From those pics (see CorvetteForum link), you can clearly see the size and # of holes is different on top (more flow area on PF64). Not sure if that matters or not, but I'm not willing to gamble either. I'm also interested in the bypass valve settings on both.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
Thread Tools | |
