Old 10-28-2021, 10:52 AM   #1
bigalzl1
Drives: camaro
brake dust
my new zl1 2021 convertible makes significant dust on my wheels . is there a replacement pad available dust free or so? thanks
bigalzl1 is offline   Reply With Quote
Old 10-28-2021, 11:19 AM   #2
joekd
Drives: 2018 Camaro SS vert
I changed to power stop z23's on my SS vert, wheels are pretty much completely dust free and I noticed no loss of braking grip
With it being a vert it will never see a true road course session so seems to be a perfect fit for my driving
Only downside I have found is the very first cold stop (backing out of garage) is noisy, every time I use the brakes after that is fine though
joekd is offline   Reply With Quote
Old 10-28-2021, 11:33 AM   #3
gra359
gra359's Avatar
Drives: 2021 Camaro ZL1, 1970 BOSS 302
Power Stop Z26's is what I used on my ZL1. No problems at all. A lot less dust. Part # for the rear, Z26-1053. For the front, Z26-1835.
gra359 is offline   Reply With Quote
Old 10-28-2021, 11:43 AM   #4
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
Originally Posted by gra359 View Post
Power Stop Z26's is what I used on my ZL1. No problems at all. A lot less dust. Part # for the front, Z26-1053. For the rear, Z26-1835.
I use the same and way less dust. My front pads do have a little rattle over certain expansion joints that are close together, but PS is sending me another set of fronts.
I think the above part numbers are flip-flopped, front is 1835.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 10-28-2021, 12:06 PM   #5
gra359
gra359's Avatar
[QUOTE I think the above part numbers are flip-flopped, front is 1835.[/QUOTE]
You are correct. Thanks for correcting me.
Old 10-28-2021, 12:53 PM   #6
Z OH 6
Drives: 2021 Red Hot ZL1
if you want a pad that has the bite like stock but produces less dust, I recommend the Carbotech 1521 pads. The Powerstop Z26s will not dust as much as stock but they also don't have the same bite and will fade rather easily under heavy use. The Carbotech's do cost more but they're worth it if you like the stock feel but without as much dust. I run them on my ZL1 and on the C8 Z51 we had.
Old 10-28-2021, 01:50 PM   #7
bigalzl1
Drives: camaro
thanks guys, appreciated!
Old 10-28-2021, 11:33 PM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
PowerStop Z26 pads all the way around on my 2SS and the dust decreased by about 90% and the stopping power decreased by about 15%... Well worth the change if you are NOT tracking the car...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 10-29-2021, 03:11 AM   #9
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
What is the specific number for the ZL1? I found some for the SS but it says it doesn't fit ZL1
Old 10-29-2021, 03:21 AM   #10
Z OH 6
I would call them to make sure sure the part numbers haven't changed but it was:
Front: CT28951F-1521
Rear: CT28951R-1521
I paid $284 for the fronts, $214 for the rears, but you can get an additional 5% off using the coupon code Corvette Forums.com
Old 10-29-2021, 03:22 AM   #11
Wuiquen
Wuiquen's Avatar
Rear: CT28951R-1521
Thanks. I'll verify and look into it. I would also like to change my pads to reduce dust
Sent from my moto g(7) power using Tapatalk
Old 10-29-2021, 03:32 AM   #12
Z OH 6
They aren't cheap but its not like you change brake pads that often and I still like the bite of the stock pads. I've never been happy with the bite of the Power Stop Z26 pads. I haven't ran them on my ZL1 but I ran them on several Hellcat's that my wife and I owned and refused to put them on a car like my ZL1 or the C8 Z51.
Old 10-29-2021, 10:15 AM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Ill pile on for the PowerStop Z26 but you'll know the difference if you have to stand them hard, trade off is almost no dusting.
Old 11-12-2021, 08:32 PM   #14
bigalzl1
Drives: camaro
nice wheels,what make are they?
