09-27-2021, 01:06 PM | #1 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Lowered. OEM measurements?
Over the weekend I installed a set of Eibach on the car. After I got the rear in the air and supported, I realized I didn't measure fender to floor. While there's no doubt it's lowered, really just curious if it was as advertised or (I'm guessing) a little more. I swear I've seen pictures of ZL1 owners that measured before, but I can't find them to save my life.
Also had a question... After an 8 mile drive after installing them, took some measurements and 3 of the corners is sitting right at 27" with the rear driver's side at 27.25". I won't align it till end of the week in case it settles a bit, but if the dimensions don't change any suggestions to get rear passenger side up a hair more? Pics for attention and hell, even a time lapse.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
09-27-2021, 01:47 PM | #2 |
it will probably settle and lower more also thats why they recommend to wait on alignment
09-27-2021, 02:29 PM | #3 | |
The whole alignment directly after spring installation I don't necessarily agree with, I've always waited a week or so. Apparently even if Eibach installs your springs, they will align right afterwards. For OEM fender height, it seems like I remember around 27.5" front and around 27.625-27.75" rear.
09-27-2021, 02:43 PM | #4 |
yup eibach is down the street from me my buddy got his installed on his zl1 there
they did the springs on my cruze lol dont ask it was free
09-27-2021, 03:01 PM | #5 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Give it more time to settle. That said, 1/4”or 6mm variance isn’t significant. Don’t count on it being 100% identical on all 4 corners. Chances are, it wasn’t that way on your stock springs either.
09-27-2021, 05:04 PM | #6 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Stock '21 ZL1, 2,700 miles: Front (both) = 27.6", rear driver side = 28.2", rear passenger side = 27.9".
You're fretting over nothing. It's because the battery is above the rear passenger side tire, pushing that corner down 1/4".
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 Last edited by Idaho2018GTPremium; 09-27-2021 at 06:35 PM. |
09-27-2021, 06:16 PM | #7 |
You sitting in the car may drop it that last 1/4”
Looks great by the way! |
09-27-2021, 10:14 PM | #8 |
This is mine when I first did it and second picture by my shop is 4 years after I originally lowered it.
Yours will drop some but doubt it will drop too much more and its sitting perfect now, tires are almost tucked and looks good. I bet you have some pictures before you lowered it and you can see the big gap the GM does on all its 4wd Camaros.
09-28-2021, 01:34 AM | #9 | |
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1 Join Date: Aug 2016
As for the alignment, mine was spot on, but I have had other ZL1 owners complain about the Eibach alignment. I guess it just depends who you get to do it....I was lucky it seems. In any case, Eibach has always been a good set of springs, if anything to complain about they usually do not go as low as other lowering springs, but I guess they are more conservative, more on performance than for show, but always good quality and good results on the track. |
09-28-2021, 09:20 AM | #10 | |
Thanks for the measurements and agree with rest, it's never 100% perfect. Heck I was actually thrilled even the fronts matched, much less 3 of the 4. I'm not too concerned with it, only mentioned. The battery makes perfect sense for additional drop on that side. For kicks measured last night and measurements are the same. Versus your measurements does seem like it possibly dropped more than advertised, but I'm 110% happy with additional drop as I preferred a little more than 0.4". Alignment scheduled for Friday morning and new tires are next. Indicators showed I had a month (maybe 2) remaining after looking at them when lowering, but driving in the rain this morning I absolutely need tires. It's no fun doing 50 on the interstate and being all puckered up if I do any faster, lol. Likely new wheels at the same time.
10-05-2021, 10:00 AM | #11 | ||
Drives: 2021 Camaro ZL1, 1970 BOSS 302 Join Date: Dec 2020
10-05-2021, 11:50 AM | #12 |
Thanks! She loves being in the shop and to be honest that is where her and I play almost everyday. She's had full run of the place since she could walk and never slowed down. For whatever reason she's good about handling tools and remarkably keeping said tools away from painted objects. Also learns stuff from time to time, last night was applying name decals to her power wheels.
