08-16-2017, 12:08 PM | #29 |
Drives: Equinox Join Date: Jul 2016
3 of 11601876 as per bulletin.
Each part number consists of new 2 new longer bolts as well as a new clamp/retainer. |
08-16-2017, 12:17 PM | #30 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Wouldn't you need 6 then to do both sides?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
08-16-2017, 12:29 PM | #31 |
08-16-2017, 12:43 PM | #32 |
That's getting pricey to fix a GM screwup.
08-16-2017, 03:03 PM | #33 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
Should we be expecting a TSB from our dealer to get this done? I would hate to see this happen to someone going down the road at 70mph and it gives out and someone gets hurt over a known issue. I can see the lawsuits now.
08-16-2017, 04:52 PM | #34 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
I had this printed last week, close to $100 for the retainer assemblies.Sorry for the sideways pic.
08-16-2017, 04:55 PM | #35 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Any idea what the torque specs should be? I'd like to lock these down next time I'm under my car.
08-16-2017, 05:23 PM | #36 |
08-16-2017, 06:33 PM | #37 | |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
I went and checked the torque spec on my bolts, the driver side was marked properly but the passenger side was not I wonder what happened there But I set my torque wrench to 40 ft/lb and every single bolt moved so I then gave it roughly 45 deg on each and repaint penned them. Definetly advise everyone to check the torque spec they are E12, ill make a separate thread about this specifically. Not sure if I have the TSB bolts or not but I will mention it for sure when I go to the dealer. The length of the bolt isnt the important part, its that they increased the threaded portion by almost 40%! |
08-16-2017, 07:31 PM | #38 | |
For the price of the GM bolts I can buy the tools to drill and safety wire the existing bolts.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC Last edited by LibertyHill; 08-16-2017 at 08:41 PM. |
08-17-2017, 10:25 AM | #39 | ||
Also the existing bolts are TAY fasteners so you should replace them anyways. The bolts on my car have about 3-4 threads showing which is above the 2 threads showing rule of thumb, You can measure the over length to see if I have the new or old bolts though. |
08-17-2017, 12:34 PM | #40 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Curious as to when/if GM made the change on the production line and if it varies at all depending on if you have the regular diff or eLSD.
08-17-2017, 12:38 PM | #41 |
Screw that then. Any chance of finding suitable replacement bolts already drilled?
08-17-2017, 08:54 PM | #42 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
Does this apply to the V6 as well? Or is it just the V8. Mine has limited slip, but not the E-diff you are talking about.
Whiskey |
