02-26-2016, 02:38 PM | #15 |
Drives: Blown up '16 SS Join Date: Nov 2015
Doing it in the tuning is a good point, but I don't plan on tuning the car until I slap a TVS blower on there, and that's going to be a few years off.
As long as I can get assurance that the WORST thing that happens when this thing malfunctions is reduced power, I can deal with that. It's the unintended acceleration side of the coin that scares me..... |
02-26-2016, 02:41 PM | #16 |
I e-mailed this thread to their "contact us" portal on the Vitesse website.....we'll see if they write anything.....
02-26-2016, 02:41 PM | #17 | |
Drives: 2016 Camaro SS Join Date: Jan 2016
I'm not trying to be negative towards Vitesse. I'm just trying to point out that there are very real unintended consequences running a device like this. Most people would not be in a position to take on the liability if something went horribly wrong out on the streets and it was found this device was the root cause. |
02-26-2016, 02:46 PM | #18 | |
I'm not looking for Vitesse's sworn word, schematics, or source code. I simply want to know what happens when this thing malfunctions. What kind of safety features are built into it? Are there any? |
02-26-2016, 04:18 PM | #19 | |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
In case something goes wrong or if our Controller detects the slightest voltage difference between the gas pedal sensor and the throttle body's sensor, it will default back to SP0 (Stock mode).The Gas Pedal's built in sensors will tell the ECU to go into the "Reduced Engine Power". This is a feature built in all the "Drive by wire" systems. No update so far guys. I was told that it is still being looked at by one of technicians. Hopefully I can get her back by the end of the day. |
02-26-2016, 04:31 PM | #20 | |
So do you think this is probably what happened to your car? Starting to sound like it....I would send the unit back to Ahmed just for piece of mind, or so they can investigate whether they have a QC problem. |
02-26-2016, 04:51 PM | #21 |
I'm almost certain that's what happened now. I did send Ahmed a PM. Vitesse is a forum sponsor and Ahmed's screen name is Horizon670. He's pretty good about responding to pm's. To answer your other questions regarding if the connections were all secure, yes they were. In fact I had the darnedest time trying to get that thing off.
02-26-2016, 04:55 PM | #22 | |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
02-26-2016, 05:10 PM | #23 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
Thank you for letting us know about this issue.
First, let me explain in more details about the Safety options we have: All GM cars with the "Drive by Wire" system have a safety feature that will make the ECU default to the safety mode, in our case for the Gen5 and Gen6, it's what we call "Reduced Engine Power" mode. This can be triggered by hundreds of sensors that are supposed to communicate with each other and receive exact voltages to function properly. We've seen TPS ( Throttle position sensors ) going bad, APS ( Accelerator position sensors ) that needed replacement... I'm not saying this is your case. The P2138 error is obviously the Controller sending a high voltage signal ( Above the 5% threshold limit accepted by the ECU ), anything slightly above and the ECU will signal that. This can happen if you did not calibrate the controller properly, a loose harness or a loose single wire... I also want to assure some of you that questioned this before, "What if the Controller breaks down or anything ? " The Controller will also default back to SP0 ( Stock mode ) if anything is not right within. If you ever get the Reduced Engine power while driving, the easiest way to fix it is to switch the mode back to SP0, park in a safe place, switch off the engine and back on. The Check engine light may not go away until the ECU checks everything after 5 restarts. Any other questions, don't hesitate to call us, we're here anytime of the day to assist you with your installs or issues. |
02-26-2016, 05:16 PM | #24 | |
02-26-2016, 05:49 PM | #25 | |
02-26-2016, 05:54 PM | #26 |
Try re-calibrating it first. If it ever happens again, we'll exchange it for you.
02-26-2016, 06:06 PM | #27 |
02-26-2016, 06:16 PM | #28 |
Drives: 2016 Camaro SS - A8, MRC, NPP Join Date: Apr 2009
Are you putting the controller back in?
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle: 2001 C5 Corvette Previous Cars: 2009 C6 Z06 2008 C6 Z51 PKG |
