04-14-2021, 08:30 AM | #15 |
Drives: Camaro LT1 Join Date: Dec 2020
Soooo, To the guy filming with the potato, what are you saying bruh?
2021 Red Hot LT1
04-14-2021, 10:10 AM | #16 |
Drives: 2023 SS 1LE Join Date: Mar 2020
04-14-2021, 10:52 AM | #17 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Does no one know that you can easily counter this by popping it into neutral or depressing the clutch while counter steering? This is an ordinary day in heavy rain for a 6th Gen
04-14-2021, 11:53 AM | #18 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
BAN LOW PERFORMANCE DRIVERS, NOT HIGH PERFORMANCE CARS!!!!! NUFF SAID!!!!!
04-14-2021, 02:26 PM | #19 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
So.... lift completely while eliminating the option to actually control the slide by removing the engine's connection to the drive wheels? Interesting theory.
04-14-2021, 10:57 PM | #20 | |
If you try to control the slide with the throttle while you're already in a slide that is out of control, adding power is only going to go the route of the Mustang, that is a period when you need the least amount of power into the drive wheels as possible. I've done this plenty of times on ice and hydroplaning in both 4th and 6th gens and it works MUCH better than leaving it in gear and hoping for the best. Last edited by Need4Camaro; 04-14-2021 at 11:09 PM. |
04-14-2021, 11:11 PM | #21 |
Camaro6 2016-2018
Drives: sometimes Join Date: Mar 2008
i knew they couldn't go around corners; turns out they can't go straight either.
04-15-2021, 08:04 AM | #22 |
Drives: 21 Camaro RS manual v6.Tyota Tacoma Join Date: Feb 2021
04-15-2021, 09:50 AM | #23 |
Who knows. Must be a foreign language!
04-15-2021, 10:07 AM | #24 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
04-15-2021, 10:23 AM | #25 | |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
04-15-2021, 10:25 AM | #26 |
Probably crossed the border a week ago.
04-15-2021, 10:37 AM | #27 | |
04-15-2021, 11:31 AM | #28 |
LT1_Radenso
Drives: a 2 spd water bottle Join Date: Sep 2017
Aren't LT1s also likely or prone to doing this though?
