04-09-2021, 08:08 PM | #1 |
Drives: Camaro 2021 ZL1 6 speed ragtop Join Date: Apr 2020
Factory alignment off? Or GY Eagles
I have a 2021 ZL1 with 1500 miles with Good Year Eagles. The front tires outside tire groove is 1/8 of an inch deep on both front tires. The other grooves all are normal depth. Is my toe way off or is this the tire design ?
04-09-2021, 08:57 PM | #2 |
If you corner hard, that's normal for the outside tread to wear down faster than the inside.
Cars I own/drive:
04-09-2021, 09:03 PM | #3 |
I don’t and don’t break on the corners. I did just look at the tires on Tire Rack and the picture looks like the outside groove is shallow. So I think it might be the design. Hoping to get a response from someone with the same tires with low Milage. Wonder if theirs are the same?
04-12-2021, 02:23 PM | #4 |
Drives: 2013 C6Z06 Join Date: Nov 2016
The tires are molded that way. Look at the little dots not the grooves on the outside for tread depth. This question pops up every week.
Old Ride: 2016 Callaway SC630 Camaro SS
04-12-2021, 02:25 PM | #5 |
17’ Hyper Blue 2SS
It’s just the tires... They’re notorious for wearing out very quickly, notably why many of us swap them out asap for another tire.
04-12-2021, 02:34 PM | #6 |
Thanks. Well my intention is to “drive the car like it belongs yo my brother in law” so they should not last long
04-12-2021, 02:40 PM | #7 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Supercar 3 doesn't last long but it's pretty good for dual-duty(track and street) and it's also pretty cheap to replace as far as big fat tires go.
If you want something more street-friendly a lot of people just use Michelin PS4S, just be prepared to pay up.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
04-13-2021, 07:16 AM | #8 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Factory alignments can be off, way off, in my area there's no charge to get it on the rack and check it. If it's out then it's $80-$100. Somewhere along the line mine was toed out as I remember, cost me a front set a bit sooner than it should have. Most likely was bad off the assembly line but had no apparent drivability issues, just wore our the inner shoulder in 10K.
04-13-2021, 07:42 AM | #9 | |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
Exactly this! I just ordered new GoodYear Eagle F1 Asymmetric 3 tires, and the outside thread depth is very shallow compared to the inside. |
04-13-2021, 08:19 AM | #10 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
I would check your alignment just in case.......
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
04-13-2021, 01:29 PM | #11 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
My Goodyear's on my 2 SS wore on the outside as well. I know they are different componnd and they lasted 11,000 miles. When I had new Michelin Sport 4 S put on they did an alignment. I asked the tech if it was out of alignment and he said just one rear tire ( I remember kissing a curb on that tire a few months before) so I would say that is normal for your GY's.
Thread Tools | |
