Old 04-02-2021, 08:52 AM   #1
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
355 rear 295 Acr tire question
Will the computer not like 355 30 19 in back and 295 25 19 in front does it mess with the speed sensor or something? Is the profile to far apart as far as height?
If so is there a way around it?
Old 04-02-2021, 08:57 AM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
I would check the revolutions per mile. If it is greater than a 3-5% difference, then I would be more concerned about the ABS kicking in inappropriately.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-02-2021, 09:39 AM   #3
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
My limited understanding of how the system works:
Part of the calculation is wheel speed in relation to the other wheels and if a wheel with a different speed is experiencing wheel spin.
With different profiles, the rotational speed is always different and the traction system freaks out because there is no wheel spin.
I don't know what the tolerance is that will trigger the system.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 04-02-2021, 11:01 AM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Do not run the narrow 295 ACR's in the front, I have been running the 355 ACR's in the rear for all last season with the 305/30r19 RE-71r front and love it. Once the 71's are cooked I will be swapping over to the Falken RT660 315/30r19 front with the ACR's in the rear.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 04-02-2021, 12:26 PM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Okay ty
Old 04-05-2021, 10:05 AM   #6
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Didn't you ask this question 2 years ago and we told you it wouldn't work back then?
Old Ride: 2016 Callaway SC630 Camaro SS
Old 04-05-2021, 10:44 AM   #7
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
355 square !!!!
That1guy_tim is offline   Reply With Quote
Old 04-06-2021, 10:57 AM   #8
ICTsccaCamaro
ITCRNRS
Originally Posted by That1guy_tim View Post
355 square !!!!
I think you would need to cut the front fenders off
Old 04-09-2021, 03:17 PM   #9
cbourbs
cbourbs's Avatar
Drives: 2019 ZL1 1LE
Are your wheels the same size as the stock ones? Will 355 fit on the stock ZL1 1lE rims?
cbourbs is offline   Reply With Quote
Old 04-11-2021, 01:44 PM   #10
ICTsccaCamaro
ITCRNRS
Stock ZL1 1LE wheels running about -2.2* rear camber to help tuck the rear tires into the wheel wells under compression.
Old 04-11-2021, 08:25 PM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Said it might mess with the sensors.. not a definite yes.
I wanted to ask again for a definite yes not a maybe or might.
Old 04-12-2021, 01:55 PM   #12
TheRealJA105
Drives: 2013 C6Z06
No one is trying it because they know it will affect the sensors.
Here's what I can tell you for a fact. The last time i wanted to finish off a set of 285/30R20 G3 fronts that wouldn't last another trackday I swapped those wheels to the rear and put my 19s with the 295/25R19 ACR tires on the front. Well I made it about 2 miles and every light on the dash lit up like a Xmas tree. I was surprised that it still let me do burnouts and donuts, but no way I'd drive it on track like that. 355/30R19 tires are a larger diameter than 285/30R20 so it will be even worse.
