02-03-2021, 01:58 PM | #15 | |
Drives: 2019 ZLE Join Date: Jul 2020
02-03-2021, 08:01 PM | #16 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I was too lazy to pull the wheels off but this is at least shot through the spokes of both front wheels
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
02-04-2021, 12:56 AM | #17 |
Textbook pad deposits.
02-04-2021, 01:09 AM | #18 |
Drives: 2018 Torch Red SS 1LE with Whipple Join Date: Jul 2018
I had a similar shuddering/vibration. I used the coarse hone on my rotors and also switched to Raybestos ST43 pads. Vibration gone!
2018 Torch Red SS 1LE, Whipple supercharger, custom tune, Rotofab CAI, ZL1 duckbill spoiler
02-04-2021, 07:59 AM | #19 |
ITCRNRS
Nice! Thanks guys, I ordered the coarse dingle ball hone linked above and will hit the rotors when I get the car up on the lift for this seasons pre-track fluid changes and alignment.
02-07-2021, 04:55 AM | #20 |
Drives: 2018 ZL1, 2001 Z28 1LE Join Date: Dec 2013
Let me know how it goes. I've been having the same issue ever since my last track outing with new factory pads.. Contemplating buying race pads and just sheering off the layer of deposit as suggested in here
02-09-2021, 08:16 AM | #21 |
ITCRNRS
Got the hone yesterday, now to get the 1in of snow and ice off the roads. Also just so it is known I am running factory pads still for future information
03-22-2021, 01:41 PM | #22 |
ITCRNRS
Follow up on the brake hone, I honed the crap out of both front rotors and reinstalled and still had a massive vibration, said screw it and pulled them off again and put them on the brake lathe at work and found the right rotor was pretty badly wrapped, but oddly enough the left rotor was still very true.
I went ahead and turned both rotors and measured and was still a good amount above min. thickness, so I used the brake hone to put and nice non-directional finish on them and reinstalled. Nice and smooth braking now, we will see how they hold up to this track and autocross season, the tow truck got sold and the new ordered truck isn't here yet so it maybe a few months before it hits the any more events.
03-22-2021, 04:13 PM | #23 |
Drives: Camaro ZL1 Join Date: Jan 2018
You obviously need different pads for what you are doing. Had the same experience, once I drove the car faster, the brakes were giving up.
I put on a set of Hawk DTC-70s all around with titanium shims and the issue was sorted out. Also enjoyed the bite these pads had very much. As I am relocating countries I am selling my pad set, they are around 80% and I sell them including the titanium shims which protect your brake calipers and keep the temperature out of the brake fluid. I also happen to have a set of Kevlar brake lines for a killer setup, those are unused, I never got to fit them. Send me a PN if you are interested, I am in Overland Park KS. |
03-22-2021, 04:58 PM | #24 |
I just got this article on brake vibration from Grassroots. It's a long read but very informative. I pulled these two paragraphs out.
https://grassrootsmotorsports.com/ar...tomation+Email In nearly every single case, warped rotors are not physically warped at all. The common misconception is that the rotors get hot enough to distort and then, upon cooling, end up looking like a pretzel. Contrary to popular belief, rotors simply do not warp in this fashion. The vibration that is felt in the steering wheel and floorboard is almost always caused by rotor thickness variation, also known as TV, and the physical pulsing in the brake pedal is nearly always a direct result of the caliper piston extending and retracting as it tries to follow a rotor of varying surface thickness. |
03-22-2021, 08:15 PM | #25 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Like others have said running some aggressive track pads with lathe the old material off and give you a fresh surface. I used St43 to do that and it was like having a brand new rotor again.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
03-24-2021, 09:55 AM | #26 |
ITCRNRS
My issue was unfortunately a wrapped rotor, not just pad deposits.
03-24-2021, 10:27 AM | #27 |
Thank you Al Oppenheiser!
Interesting. Haven't seen a lot of posts with warped rotors. How many thou of runout was there on the bad one?
Glad you got it sorted. |
03-24-2021, 11:23 AM | #28 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
If it is a hardened hot spot issue, you'd have had a little difficulty getting a uniform cut and the problem is pretty much guaranteed to return - and not because you've machined material off of the rotor. Norm
'19 WRX 6M (the family sedan . . . seriously) |
