05-10-2022, 10:16 AM | #1 |
Drives: 2017 2SS Camaro Join Date: Mar 2015
FIX 82 inputs
Hi All,
I have embraced the car audio bug that has bitten me over the long winter. I have collected all my parts and I am ready to lay down some fiberglass in the next week or two if temperatures will allow me to. Hoping to have the whole system done for the end of May or June. Clearly I am not in a rush and want to make sure I do this properly this time. Up until now I have just been running a couple 500W amps into a couple 12" kicker L7's with a LC2I line level converter. It has been great for all the bass in the rap world, however, I listen to a lot of rock as well as rap and would love to get some mids and highs heightened to enjoy some rock. Now its time to get serious! I have a 2SS w/Bose. This list of parts I have compiled so far is: Front: Focal PS165F Flax 6.5 Inch 2-Way Component Kit Rear Deck: Alpine X-S69C X-Series 6x9 Inch Component 2-Way Front, rear fill amp: Alpine X-A70F 120 x 4 Subs: Two - Kicker 12" L7 Sub amp: Two - Alpine X-A90M 900W x 1 DSP: JL Audio Fix 82, JL Audio TWK D8 It has been a few years since I have been into car audio and the game has changed since having to simply replace the head unit and run RCA's ,+/- and remote wires. This will be the first time I have had to use a DSP to get a "clean signal". So after explaining my starting point, here is my question: Which speakers do I use for each of the 8 channels going into the FIX 82? This is what I am thinking but I am not 100% sure. Channel 1 - front left tweeter Channel 2 - front right tweeter Channel 3 - front left door Channel 4 - front right door Channel 5 - N/A Channel 6 - N/A Channel 7 - N/A Channel 8 - N/A This should give me both high and low signals to sum. no? Because the FIX 82 only has 2 outputs, would this be enough just to get the "clean signal" out and run daisy chain to all 3 of my amps and use the crossovers on the amps to select the highs and lows? I am confused because of the chime signals that I don't want to introduce into the amplifiers. I have read that the blinkers run through the front left tweet and back up sensors run through the rear left and who knows where the door chimes and seatbelt chimes run through. I know this is long winded to ask a simple question, but the more info I can provide, the clearer answer I seek. Thanks in advance. Kevin
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
05-10-2022, 01:59 PM | #2 |
Drives: Chevy Camaro Join Date: Apr 2020
Here is what the channels do
05-10-2022, 04:58 PM | #3 |
Yes, I see that in the manual. My concern is more of the chimes, back up sensors ect. I see yours only has 4 channels used (purple, green, white and grey). I am wondering which speakers off the Bose amp your are using for these channels. I don't want to assume that these are the stock car wiring colors and bugger something up. this shit is expensive. haha
Do you have any issues with amplified chimes using that set up?
05-11-2022, 03:04 AM | #4 | |
05-11-2022, 09:20 AM | #5 | |
I wanted to go all Alpine X series when I was designing this system. But the Focal component set showed up, unused on marketplace for a steal. so I grabbed it. I am toying with the idea of using the 6X9 Alpine X component set I have for the front and putting the focal in the back. It would require less modifications than the 6.5 Focals. I have always been an Alpine guy since I was a teen.
05-17-2022, 09:42 AM | #6 | |
At this point I am actually think of getting a shop to do the install of these two components, But I know they will not want the work if it is only partial. Like a mechanic installing the blower and allowing the customer to install the intercooler plumbing.
05-25-2022, 12:15 PM | #7 | |
Electrical Engineer
The issue with shops taking a partial project is finger pointing if something doesn't work - not worth the liability. You can get the factory schematics from ACDelcoTDS and just buy a 3-day access and then print-to-PDF anything you want to save. I have both Bose and Non-Bose radio systems schematics saved. I'll be using the newest JL VXi series of amplifiers and handling the DSP corrections within the amp and saving a few components. I have a video showing how I perform factory EQ corrections with the VXi amps - but I don't run rear fill and focus on front component, full-active, SQ builds. Rears in this car seem like a poor use of money if the goal is SQ. If the budget isn't being split between front and rear speakers (meaning the nicest speakers you want can be bought for both front and rear) then having presets and a fader let you run rears as the situation calls for. I always recommend spending all of the speaker budget on front components.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
05-31-2022, 02:12 PM | #8 | |
06-01-2022, 02:28 PM | #9 | |
Electrical Engineer
06-04-2022, 01:09 PM | #10 |
Drives: 2021 Camaro 2SS 1LE M6 Join Date: Jun 2021
I created a thread with my experiences using the Fix86. I haven't gotten to the Twk 88 section yet, but I have posted some information about using the Fix86 which I think would really help you.
https://www.camaro6.com/forums/showthread.php?t=606205 |
06-07-2022, 03:41 PM | #11 | |
