01-22-2020, 09:54 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Jan 2020
FS: 2018 ZL1 Fully Built- Procharger
2018 ZL1 with PDR.
Tim king built the car from the ground up.. -416 CI LME motor, have build sheet, best of the best. Billet intake by LME -F1X Head Unit - air to water, tank in trunk, also retains heat exchanger for street cruising. - Crawford port injection HOLLEY dominator/ dual wideband ID 1300 injectors - primary has Fore Fuel system triple in tank pumps with FLEX Fuel. - waste gate setup, with dominator boost controller / control boost on digital screen from 14-28 lbs - 15x10 weld bead locks and 18x6 front welds - 2 inch headers, Magnaflow cat back exhaust - Carlyle brake conversion for 15s with upper and lower control arms - DSS driveshaft - transmission built by RPM - stock new converter when trans was built Car has 6041 miles, 1 owner. No accidents, no bs. No leaks, runs on pump e85. Car was paint corrected and ceramic coated. Everything works as it should, no check engine light, just your normal rear tire pressure low from running the tires at 25. I have the stock wheels, and some stock parts. $78,000 obo Last edited by ZLWONN; 01-23-2020 at 08:23 AM. Reason: added exhaust |
01-22-2020, 09:57 PM | #2 |
Engine pic
02-16-2020, 10:30 AM | #3 |
Drives: 2016 SS Join Date: Jan 2018
PM sent....
02-22-2020, 04:19 PM | #4 |
T t t
03-04-2020, 06:08 AM | #5 |
T t t
03-19-2020, 06:56 AM | #6 |
Up up
04-06-2020, 11:19 AM | #7 |
Drives: 2010 Camaro Join Date: May 2015
Is this still available? PM me please.
04-13-2020, 06:01 PM | #8 |
Drives: 2018 camaro zl1 Join Date: Apr 2020
Hi is this zl1 still available if so can you call/text me 202-471-0629 I am very interested
