12-17-2018, 11:10 PM | #1 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
DSX Baro Breakout Harness - Centrifugal
So I am in the middle of putting a ECS / Novi 1500 on my 1LE, and my tuner informed me to buy a DSX Baro Breakout Harness that has an additional IAT sensor and a LSA MAP sensor
That being said - I am curious about the function of the harness. Is it there to run two MAP sensors (one in the intake & one atmosphere)? The other question is - where should I mount the IAT sensor? Anyone running one of these?
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
12-18-2018, 03:45 AM | #2 | |
The separate IAT sensor, it seems that people put them in the intake manifold, behind the throttle body. The reason they do this seems to be, that they are using methanol injection, and this way, the IAT sensor sees a cooler temp from the methanol. |
12-18-2018, 06:24 AM | #3 |
wnta1ss - thanks for the feedback
where is the 1bar MAP located at on your engine? Just out of curiosity?
12-18-2018, 08:53 AM | #4 |
Drives: SS 6 speed of course Join Date: Jan 2016
I thought the temp was moved because the PD setup has the temp pickup after the rotors? The centri people have it after the intercooler but before the TB in the MAF i.e. the stock LT1 location.
12-19-2018, 03:37 AM | #5 |
12-19-2018, 05:42 AM | #6 | |
Drives: 2016 Garnet Red 2SS A8 Join Date: Jul 2017
I will installing a P1X this week and just received my harness but did not see any instructions. |
12-19-2018, 05:58 AM | #7 | |
12-19-2018, 06:43 PM | #8 |
Thanks, I was obviously confused. Does the new sensor still simply hang from the harness or is there a good way to mount it?
12-20-2018, 04:08 AM | #9 |
I did not see a good way to mount it, so had zip-tied it to the wiring bundle on the driver's side of the engine and made sure the nipple was open to the air, not resting against anything.
01-30-2020, 10:11 AM | #10 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
did you all ever figure this out? or have complaints about this setup? pictures? i'm about to install
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-30-2020, 10:27 AM | #11 | |
I mounted it close to the air filter on my s/c (within a couple of inches) and if you log it, you can see the ambient air pressure rise as the speed in the car rises (about .7-.8lbs). That is something they can't "cheat" in on the tune. Given the price and how easy it is to install, I dont see why anyone would not do it.
01-31-2020, 06:04 AM | #12 | |
01-31-2020, 08:17 AM | #13 | |
On my car I am using a Banks iGauge, and it shows me both sensors to monitor, and when looking at both, you could see the delta change (both would show the same pressure at idle and low speed, but would deviate farther and farther the faster it went, up until about 100mph where it stopped climbing. I think it is just an area of high pressure located under the hood. With the ECS kit you take all of the rubber & plastic trim out from around the radiator, core support, headlights and such so I think this could induce a lot more air under the hood than normal. It was known with Cup cars that there was substantial positive air pressure at the base of the windshield, hence why they have their air intakes up on the cowl.
01-31-2020, 08:47 AM | #14 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Here is the reasoning for breaking the Baro out of the MAF and or also the IAT.
If you want to be able to see what boost you are making you want to change the intake manifold (IM) map out from a 2 bar to a 3 bar map sensor. With that the MAF also has a MAP in it in the form of a barometric pressure sensor. The ECM uses the Baro sensor to determine the outside relative barometric pressure. Using the DSX Baro or Baro/IAT breaking allows the ECM to now see the Barometric pressure from outside the MAF and the charge tube while using the 3 bar map in the IM to see the actual boosted pressure after the MAF. The benefit of moving the IAT out of the MAF is you can relocate it to after the meth injection and be able to see the actual temps after the meth injection has been ran. If you do this, and this is something I just learned last night (huge thanks to DSX Tuning for helping me out this by the way) you will need to fix the IAT2 table in the ECM programming. This part is super easy to do if you are using HP Tuners, if not you will need your tuner to do this. Go to the HPT tune repository and find and download a stock OEM 2013 Cadillac CTS-V (gen 2) tune. I found one for a M6 in there last night. Copy the IAT2 table from that tune and put it into your IAT2 table, save the tune and then flash it. If you breakout the IAT using the DSX Baro/IAT breakout this will do a couple of things for you. The Baro breakout moves the ambient temp sensor out of the MAF and into the engine bay. The Baro sensor handles the Barometric pressure reading and the ambient temperature as well. The infotainment system gets its ambient temperature reading from the sensor in the nose mounted to the radiator core support. By copying the CTS-V2 IAT2 table into your table you can now log "Ambient temperature" and "IAT temperature" and be able to see the actual outside air temps the ECM is seeing via the IAT2 (Baro sensor) and the IAT temps the engine is seeing. This doesnt do anything for the fueling at all, but the IAT temps do have a timing modifier table they reference that can affect timing depending on how your tuner has modified the IAT table. I hope this helps you all out. It has been a nice learning curve playing with these sensors and getting the actual data. Since I moved my IAT into the IM I can now see what the ambient temps are while driving. So now I can see how far off the intercooler is from ambient temps, I can see how my IAT looks while at boost before the meth injection kicks in and after the meth injection kicks in. Now I can see how the IAT timing table is working as well and use that table to make adjustments accordingly.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
