Old 01-22-2022, 11:36 PM   #1
Vhp04
Drives: 2018 camaro zl1
Spark plug NGK 6510
I got A little over 1,000 rwhp, and I just put this NGK 6510 spark plugs but they came at .040 is that good or should I close them down a bit. want my car to be running the way it should it wonít hurt it if I leave it how they came?
Vhp04 is offline   Reply With Quote
Old 01-23-2022, 12:17 AM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Depends on your boost bud. If over 15lbs of boost gap them at .028
815rwhp/760rwtq - 93 | 850rwhp/765rwrq - E40 SAE
Magnuson 2650 90mm upper w/13% lower (9.06)
CSP Big Boy Cam w/32% fuel lobe
Heads done by LME (Full new Valvetrain)
NW 103mm TB
Roto Fab Big Gulp
CSP 2" Headers w/Green GESI Gen 2 Cats
Borla 3" Full Cat Back w/ S-Type
Mighty Mouse Wild Catch Can
Custom Holley Low side Fuel system
Forced Inductions Interchiller w/2 gallon fender tank.
Old 01-23-2022, 08:44 AM   #3
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
What about for a ported stock blower at say 10Ė12 lbs of boost? .032ish?
On the Korn
Kong Stage X Port, LPE Big Bore HPFP, Big Gulp, NW103, XDI +30 Injectors, ARH Coated Headers, dual X-pipes, MBRP resonators, AWE Touring, FlexFuel, JMS Booster, Elite E2-X CC and ADMv2 Reservoir. Stock motor, stock heads/cam, stock pulleys 714/661 SAE
CW3SF is offline   Reply With Quote
Old 01-23-2022, 07:11 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think JRE's been pushing around .040" for up to that boost.
I'm at about 700, and just put in 6509s, and with about 15-lbs, and .040", it sure is snappy.
'20 ZL1 Black "Fury"
Magnuson Magnum DI TVS2650R / HHP TCM / PLM Heat Exchanger / ZLE Cradle bushings / BMR Chassis-Suspension Stuff / aFe bars / 17" Drag Pack / Diode Dynamics LEDs / ACS Composites Guards / CF Dash / tint / other stuffs
Old 01-23-2022, 07:26 PM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
It’s not going to make anymore power or run better at .040. I can’t run .040 on mine, I tried once, misfires once it gets close to 15psi. The coils/wires etc have enough voltage to jump the gap but blowout becomes an issue.
NW 103mm TB
Roto Fab Big Gulp
Old 01-23-2022, 07:28 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Camaro1973 View Post
Itís not going to make anymore power or run better at .040, a burn is a burn. I canít run .040 on mine, I tried once, misfires once it gets close to 15psi.
I'm only offering what's been posted here, as best as I can remember, and my experience. You're making a lot more power than I, so I don't know that I would be surprised by your experience. I'm certainly no expert
Old 01-23-2022, 07:28 PM   #7
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
A safe bet IMO would be .032 . Itís not worth risking spark blowout at .040, esp with no difference except a possible smoother idle.
NW 103mm TB
Roto Fab Big Gulp
Old 01-23-2022, 07:35 PM   #8
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I mean if the car is mostly stock esp with no cam running the highest gap is mainly better for idle. Iíve seen no performance improvements with a larger gap.
Basically you want to run the largest gap you can without spark blowout.
Stockish 9-11 psi is good for .040
Modded 12- 13 I like 0.32
14-17 I like 0.28
This is JMO but I think these gaps work best.
NW 103mm TB
Roto Fab Big Gulp
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
