01-22-2022, 08:33 AM | #43 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I had my nearly stock (Rotofab intake) 2017 SS dyno tuned. It has the 8-speed auto trans. Below is the chart showing untuned, tuned, and with e85. This was on a calibrated Mustang dyno. Stock = 372 WHP, 390 WTQ Tuned = 393 WHP, 416 WTQ E85 (E67 actual) = 417 WHP, 441 WTQ |
01-22-2022, 02:21 PM | #44 |
Madman
Drives: 2018 2SS Optioned 6spd Summit White Join Date: Aug 2020
Dyno comp uses a calibrated dyno jet
Do they tend to read higher than mustang dynos? I’m getting curious too Ur car put down 40 wtq less and u have an intake and e85 Why do u think that is ? Auto vs manual? |
01-22-2022, 02:45 PM | #45 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
The operator of the dyno is pumping up the numbers for the OP or the dyno is messed up. Space's dyno sheet lines up with the rest of the cars with the same mods. Even if he had a manual he'd still be about 430 with his mods. So no It's not a auto vs manual thing.
01-22-2022, 03:15 PM | #46 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
I hear if you tap up, up, down, down, left, right, left, right, B, A, select, start on the steering wheel controls, it'll put your car in super pursuit mode. I'm perfectly ok with millennials not getting this reference.
01-22-2022, 03:42 PM | #47 |
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
Why is my PP so big?!
01-22-2022, 07:15 PM | #48 |
Some of us millennials grew up playing Contra
01-22-2022, 07:28 PM | #49 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
01-22-2022, 07:51 PM | #50 |
01-23-2022, 05:48 AM | #51 |
Advice is, take it with a grain of salt, because that is what I'd call an internet dyno. Meaning that it gives quite inflated numbers. No way is an SS or LT1 with just a silicone intake pipe and a 91 gas tune getting 459.8 hp at the rear wheels on an honest dyno.
01-23-2022, 10:50 AM | #52 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Agreed. But for giggles I still want to see 1/4th mile times or taking it to another dyno.
01-23-2022, 04:15 PM | #53 |
Madman
Could putting the engine under more vac make more power ? Better seal etc as far as pcv goes
01-23-2022, 11:12 PM | #54 |
Drives: 2022 SS 1LE Join Date: Dec 2021
01-25-2022, 10:10 AM | #55 | |
Drives: 2022 Camaro Join Date: Jan 2022
No
2022 1SS A10, NPP, Recaros, Sunroof, Carbon Flash Blade spoiler, Carbon Flash Splitter, Red Calipers, Carbon Flash Wheels,
Black Camaro Fender Badge, Black wheel nuts & locks, Black fuel door w/carbon fiber, Red hash marks, Red seat belts, Black SS wheel caps, Black Camaro fender emblem, Carbon fiber shift knob, Battery protection package |
01-25-2022, 12:45 PM | #56 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
If other SS Camaros were dynoing much less HP on that same dyno then you could certainly say that you have an abnormally high HP. But without knowing what others have dynoed at then no, you can't really say that. Unless the operator tells you that yours is the highest he has seen...which, trust me, they say to everyone.
Sometimes dynos get updates which change the way they rate things. It could be lower, it could be higher, etc...other times you can input info into them which changes the output reading. Sometimes a particular car on a particular dyno on a particular day at a particular time during particular weather conditions just might read higher than normal for varying reasons. Or the specs on your engine parts might all be slightly off on the generous end and might make for a higher HP engine. Who knows? There are many reasons why you might actually have a higher HP engine or why it might just have read higher or how the operator could have manipulated it to read higher. These days people want high numbers for little to no work, money, time, or effort. Some dyno shops recognize that and will pander to that mentality because they know that most people will go to dyno A if they always read even 1 RWHP higher than others. Or dyno operators plug in factors so they can say that your numbers "would be this if". And that makes people happy and keeps their business rolling in. Now some dyno shops will tell you "hey look, you're not gonna get reality bending numbers here but we will give you an accurate reading". Those shops are typically the honest ones because they aren't gonna feed your ego with high numbers. So if you really want an honest assessment, find a different shop and get it dynoed there and see how the numbers compare. And FTR, my ZL1 after full mods dynoed at 740 RWHP on 93 octane on a Dynojet and then 689 RWHP on a Mustang dyno. Like I said, most people will go to the shop that has the dynojet. But then that person might be running around claiming he has 740+ and then line up and get gapped by someone who says they have 680. So it is always best to know what reality is and an honest assessment of your car. Because believe me, some of these guys out here claiming they have 800 and 900 are actually nowhere even close to that. Until you dyno and compare with another SS or even a couple others on the same dyno you won't know for sure if you're actually higher than normal. |
