![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
OCTANE LEVEL SWEET SPOT FOR CAMMED 2650 MAGGIE??
Hey Guys, I am putting the car in the shop later this week for the install of Jannettys Terminator Cam / 2650 Maggie package w/ +30 FICs. I am curious to find if there is a octane sweet spot for this build like there is for E (60%) with the JRE 125 Flex Fuel build. I can get 110 race fuel by the barrel, leaded and unleaded. What do you guys think. Thanks in advance.
JRE Terminator Rough Idle Cam - Magnuson 2650 build w/ FIC+30%'s, NW 103mm TB, 9.34" (15%) lower pulley, 90mm upper, Elite CC, Cordes Expansion tank, JRE street tune. 2" TSP LT's (catless) to stock suitcase.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
E60 is still the sweet spot.
2016 NGM 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP |
I am not going to be able to run ethanol - I'm staying with the stock LT4 fuel system with the JMS voltage booster and +30s the only upgrade. So, is there a particular octane content that is the most efficient? Should I shoot for a 100 octane tune, a 105 or 95? I guess what I'm asking is is the boost in horsepower linear to the octane level? Lastly, since I have no cats, should I run leaded gas?
#4 | |
On the Korn
Kong Stage X Port, LPE Big Bore HPFP, Big Gulp, NW103, XDI +30 Injectors, ARH Coated Headers, dual X-pipes, MBRP resonators, AWE Touring, FlexFuel, JMS Booster, Elite E2-X CC and ADMv2 Reservoir. Stock motor, stock heads, stock cam, stock pulleys 714/661 SAE |
#5 | |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
I know so many people who thought 100 octane was going to be okay.... but then they end up not driving their cars because of fuel limitations. |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
95-97 using fuel additive put me into the 26-27° degree timing area easily/safely with my 2300.
I'm on 50/50 methanol right now and seems to have put me there plus some in equivalent octane, I can easily reach that level of timing without knock while on 93.
2017 Camaro ZL1 Coupe M6 (847whp on Dynojet)
#7 | |
![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Just run a 93 tune and a race gas tune, youll make about 40hp or so more depending on your build. Your still going to need to watch the high side regardless.
815rwhp/760rwtq - 93 | 850rwhp/765rwrq - E40 SAE
Magnuson 2650 90mm upper w/13% lower (9.06) CSP Big Boy Cam w/32% fuel lobe Heads done by LME (Full new Valvetrain) NW 103mm TB Roto Fab Big Gulp CSP 2" Headers w/Green GESI Gen 2 Cats Borla 3" Full Cat Back w/ S-Type Mighty Mouse Wild Catch Can Custom Holley Low side Fuel system Forced Inductions Interchiller w/2 gallon fender tank. |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '20 ZLE A10 Join Date: Jun 2020
Mine is a Stage X. I decided to run 100 oct. all the time rather than E because it's so much simpler. There are two 100 pumps within 3 miles of my home. It's obvious I recommend 100.
You'll learn to put camaro1973 on your ignore list as I have. He's a troll. Quote:
HPE 850 + KongX + GT100 = 1050 bhp corrected
1.60/10.56/131 @ 8043 DA (9 runs so far) On order: Kong ZL1 EPP 2650; LPE BBDI FP; XDI +30 Some previous cars: 2016 GTR 2013 GTR 2011 BMW M3 2006 PS GTO 4-link sportsman race car (6.52/212) 2001 LS1 (9.90 at 8000DA) Last edited by JSH; 12-15-2021 at 02:11 PM. |
#9 | |
Hes not asking what you like to do. Hes asking what he should do. And weren't you banned? Shame it wasn't permanent.
#10 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I would not recommend running that high of an octane all the time on the street. 92-93 for DD purposes is the easiest and simplest way to go. Use 100 octane for a race tune.
My reasoning is that I don't think it's a good idea to always run something at it's max. That can lead to problems like a blown engine. A 93 octane flex tune is where you want to be safely for DD. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sure, higher Oct will net more timing and hp, however, unless you are only bringing the car out for some drag action and constantly running very low tire pressure on drag radials you will not make use of your 93 tune nonetheless a 100+ Oct tune. It is a shame you are not gonna do e since u have the injectors going in.
IMO, most run 100(or MS109 equivalent) as a high Oct tune to answer ur question.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#12 | |
#13 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Me and a few others with maggie 2650 cars can't run ethanol unless it's a small blend like E30 maybe. Typically we run on 93 and then use race gas for race days/nights. It's worth anywhere from 50-100 whp.
We have just cam, lt4 system, and dsx low side. No injectors, but I'm not sure how much those would even help. |
#14 |
You may find you can't run full e85, but as JasonGoFast said you could run a blend. Those injectors should help quite a bit in lowering your inj pw. I did the DSX lower aux pump instead of the booster and have no issues on the low side keeping 79-80psi wot. You may ask them to add the Lingenfelter high flow check valve to it. It wont cost a lot and will help keep the flow up.
Thread Tools | |
