![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Who Rebuilds Brake Calibers???
As we are nearing Road Racing season down here is TEXAS I was wondering who has had a good first hand experience with someone who rebuilds calibers. There is NOTHING wrong with mine currently (ZL1 1LE) but I think it is a good idea to replace the piston seals and possible upgrade the brake pistons themselves if that option is available.
I know I got them hot enough this season to turn my pretty SILVER calibers into a GOLD color caliber (LOL). I just purchased some titanium backing plates which I will use on the freshly rebuilt setup. I typically use DTC70 and DTC60 pads with slicks when racing and the stock brembo pads when I am not. THANKS!!!
Here is TAZII at the TEXAS MILE Look at 2:04 mark in Video for BLACK SS (NOW RETIRED...LOL) NOW POWERED BY PROCHARGER NEWBORN ADDITION 2019 ZL1 1LE A10 (RETIRED) 2019 Camaro SS A10 (newest kid) |
![]() Drives: 2020 ZLE Join Date: Aug 2021
In for info on cadence of needing to rebuild.
However I think Racingbrake.com has new high temp seals and better pistons for our calipers. Worth a look.
2020 ZLE A10
Rotofab, SPL suspension goods, Cobalt XR1 pads, Apex wheels |
Ok thanks. I will touch base with them.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
I’ve rebuilt several set for my 5th Gen 6 piston an my C7 GS with 6 piston fairly easy task but not worth paying someone else a shit load of money to do. Racing brake does have vented caliper pistons and hot temp seals an dust boots, kinda spendy though for sure.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components. Last edited by olblue75; 11-30-2021 at 08:55 PM. |
![]() ![]() ![]() ![]() Drives: Chevy's Join Date: May 2009
FYI, it's caliper not caliber. Anyways, PITA but not hard to get pistons out. For your J6H ZL1 fronts: just order two of 19207043 and two of 19207044. That will get you the J57 CCB caliper's vented pistons, the pressure seals, and the dust seals. The Gen 6 ZL1 front has the same size pistons including height as the front of the C6 / C7 / Z28 CCB calipers but those are vented vs. solid. Dust and piston seals are common.
I have done plenty for me and buddies. Busy this time of year, but, will be glad to give you some pointers. I've seen you car in DogHouse getting work, so, you might get a quote from Adam / Tim. With the pistons and seals out, you could have calipers re-painted or powder coated at that time. |
#6 | |
#7 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I know there's a good thread on here some where, can't seem to find it. They compare solid with vented pistons and also shows how he did the install. I believe it was all oem gm (Brembo) parts.
Found it https://www.camaro6.com/forums/showt...ans+pan&page=5 Last edited by 20Bluezl1; 11-30-2021 at 04:41 PM. |
#8 |
I wish there was a tool to install the dust boots though.
Orange Krush II
#9 |
#10 |
I rebuilt my SS 1LE fronts (my first time) and it wasn't too difficult. I do have some tips for you if you do your own. Having the service manual pages and this web page helped https://www.camaro6.com/forums/showt...=571640&page=6. Also got advice from RUQWIKR. Rebuilt using the GM vented pistons and seals, but used RB high temp dust boots. Results are great so far after 2 days at COTA and 2 days on the 3.1 using DTC60s. Don't need the Ti shims anymore either.
#11 |
![]() Drives: Camaro 1ss Join Date: Nov 2019
If you can replace your own rotors you can rebuild your calipers. It's a fairly straight forward and easy process. Tons of videos on YouTube showing you how to do it. Doesn't have to be Camaro Brembo. All Brembos are pretty much the same steps. Take your time and save yourself some money.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
#12 |
Dust boots
They can be a bit of a pain. Especially OEM ones.
Orange Krush II
#13 |
So what's the consensus here I looked up prices to compare oem to racingbrake.com.
OEM. 2- 19207043 ($180 each) 2- 19207044 ($26 each) Total $412 RACINGBRAKE.COM Rebuild kit with temp seal $612 So the oem kit are I believe stainless and vented with normal seals. As the Racingbrake kit are stainless not vented and you can get high temp seals. I'm I correct, which is the better option? Also the racingbrake pistons look hollow compared to the oem. |
#14 | |
Thread Tools | |
