09-30-2021, 11:49 AM | #1 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Cam install
I am about to attempt my cam install and I wanted to ask if you guys pull the motor for the install or leave it in? I am also installing a new oil pump and lower. Thanks ☺️
09-30-2021, 12:35 PM | #2 |
Sarcasm loading --------
If the heads are coming off I would pull it, otherwise I would leave it in.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
09-30-2021, 01:44 PM | #3 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
The shop that did mine left it in the car. They did pull the nose off the front
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-30-2021, 02:46 PM | #4 |
Here ya go https://www.camaro6.com/forums/showthread.php?t=516717 I'm sure there's other video but this one should help
'20 ZL1 1LE A10,
09-30-2021, 03:18 PM | #5 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Might as well pull it. If you do the oil pump also, you would have to remove the steering gear to be able to get the oil pan off.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
09-30-2021, 06:15 PM | #6 |
Drives: 2019 ZL1 Join Date: Mar 2019
Seems like it’s just to much hassle to do it in car. Pulling the pump, messing with timing chain and timing alignment. I think most places are just pulling the motor out now.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
10-01-2021, 04:07 AM | #7 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
10-01-2021, 04:24 AM | #8 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
Mine was pulled out
'17 ZL1 M6
8xxwhp Magnuson 2650 |
10-01-2021, 07:17 AM | #9 |
Drives: 2017 ZL1 Join Date: Jan 2017
My front subframe was dropped It's more efficient, especially if you are doing Cam, valvetrain, valley cover, oil pump, heads, etc. Less chance to damage car and all you pay is the price of an alignment at the end of the day.
10-01-2021, 07:31 AM | #10 |
BAMF SS
It just takes a few hours to pull the motor. Just pull it, that way you can do a nice clean install on a stand.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10-01-2021, 08:14 AM | #11 |
Red Bull
Thanks everyone for the input….. looks like we will pull the motor.
10-01-2021, 08:36 AM | #12 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
If your car is a M6, pulling the heads while the motor is still in the car is easier. It allows the motor to tilt upwards a good bit more before hitting the firewall which will give you the clearance you need to separate the motor and trans
Baby Blue
10-01-2021, 09:00 AM | #13 |
Droppign ths subframe is easier, but one thing that worries me about dropping the subframe is the issues some people had with their electric power steering afterward.
10-01-2021, 09:40 AM | #14 |
This is sometimes done on a manual.
