![]() Drives: 2020 V6 Auto 3LT RS Join Date: Apr 2019
Oil for 2020 Camaro V6
What is the best year around oil to use in a 2020 Camaro with V6 engine? How often do you change it (miles or time) ? Thanks
GR 2016RS
Drives: 2016 Garnet Red RS Join Date: Mar 2016
It probably says 5w30 full syn in the owners manual. I normally get about 4k out of an oil change. I use the oil tracker and change it when it gets down to 10% life.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Use the oil grade recommended in your owners manual and you will be good to go!
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Being under warranty I'd stick with the factory specs. I still do on mine as well
![]() Drives: 2018 Camaro 1LS (V6, M6) Join Date: Jul 2020
Mobil 1 5w-30 Full Synth w/ dexos2
The manual calls for an oil change every 7,000 miles, but you might want to do it every 5,000 miles if you drive like a complete jackass or track the car. |
#7 |
![]() Drives: chevrolet camaro Join Date: Feb 2021
oil change
5w30 Mobil 1 Full Synthetic....is the way to go...you'll notice difference right away...i always change my oil frequently anyway but you can go 6k-7k with this oil...but regardless, that is what I do.
Thread Tools | |
