09-26-2020, 01:03 AM | #1 |
Drives: Chevrolet Camaro LS Join Date: Jun 2020
Traction Control on a V6
I am curious, what does turning off the traction control really do on a V6 car, 6 spd. I have not noticed a difference in traction regardless of where the switch is set.
09-26-2020, 06:06 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Push the car hard enough and you should notice a difference If a wheel starts to slip the engine will reduce power/torque to the wheels; if there's still slippage the brakes will come on as required to stop any slippage.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
09-26-2020, 08:26 AM | #3 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Smooth, sexy drifts at U-turns. That is all
"Make yourself sheep and the wolves will eat you"
09-26-2020, 01:51 PM | #4 |
When it activates, does it feel like a slipping clutch?
09-26-2020, 03:10 PM | #5 |
Maybe when accelerating moderately from a stop and a tire starts slipping, like on wet or snowy roads it feels like a slipping clutch (brakes engaging); if you're turning and accelerating and gas too hard, like trying to make a quick left turn at an intersection, it feels more like you suddenly took your foot off the gas at a high RPM (power reduced).
