06-05-2013, 01:35 PM | #1 |
G200 Pilot
Drives: 2010 Camaro SS/RS purchased 5/2010 Join Date: Dec 2010
DRAG CAR/STREET LEGAL/TRAILER FOR SALE
SMOKING HOT PACKAGE DEAL....2010 CAMARO 22/RS FASTEST STREET LEGAL 5TH GEN CAMARO IN FLORIDA @9.5 148 MPH AND 4TH FASTEST IN THE WORLD (CATEGORY 7)AND HAS A LOT MORE IN IT BUT WIFE SAYS SELL!! INFERNO ORANGE METALLIC WITH CUSTOM GOLD STRIPES OVER TOP AND SS HIGHLIGHTS.... (only has 13,600 miles on it and 15 passes on the the new engine 1/4 mile track) 965 RWHP
SEE G200 PILOT https:docs.google.com/spreadsheet/1PINX0423VKRNC ENGINE: JANNETY BUILT 416 STROKER/COG DRIVE UPGRADE, 75/34/40.000X6.125 2.100 4340 EAGLE CRANKSHAFT/EAGLE H BEAN ROD 6.125X2.100/WISECO COATED 4.07015 CC IS31.110 DISH PISTONS/ROD BEARING SBC 2.100 COATED/LS MAIN BEARING COATED KIT/DIS/WASH BLOCK/HONE CYLINDERS WITH TORQUE PLATE .005/LINE HONE MAINS AND INSTALL ARP MAIN STUDS/ASSEMBLE BALANCED/HAND BLEND VALVE JOB INTO PORTS AND FLOW TEST/RESURFACE PAIR OF HEADS TO 70 CC/TOUCH UP VALVE JOB/C&C PORT CYLINDER HEADS/GEN 3 TIMING CHAIN (3/8X7/32)/ GEN 3 LS SB 2004 & LATER WITH ALL SAME LENGTH STUDS EXHAUST: 2" OFF RAOD HEADER KIT/6.23" STAINLESS COMPETITION CAT BACK, 4" TIPS JRE MODIFIED TRUE 3" VORTEC YSI RACE SUPERCHARGER : JRE SUSPENSION/90/10 FRONTS/50/50 REARS/BMR LOWER CONTROL ARMS REMOTE BATTERY DISCONNECT & HIGH AMP ALTERNATOR DISCONNECT FUEL SYSTEM: 10 AN BYPASS PRESSURE REGULATOR/STEALTH ELIMINATOR FUEL SYSTEM W/A 1000 PUMPS/SPEED CONTROLLER/FUEL RAILS/ INJECTOR DYNAMICS 1025 CC INJECTORS WHEELS AND TIRES: BOGART 16" FRONT AND REAR WHEELS/28X14.5X16 QUICK TIME HOOSIER PRO D.O.T. TIRES/TUBES/MICKEY THOMPSON DRAG RADIAL (NEW) 625 DRIVE TRAIN: 4L80 RPM TRANSMISSION/TRANS BRAKE/ 2 STEP/DDS DRIVESHAFT/9" DDS REAR END W/SHAFTS/PFADT SOLID CRADLE BUSHINGS COOLING: PT 2000 AIR TO WATER INTERCOOLER/INVERTED INLET & OUTLETS/ 10 GALLON CHILLER TANK WITH LARGE INLET CAP/MEZIER 55 GPM PUMP/PROCHARGER RACE BLOW OFF VALVE PARACHUTE SYSTEM: THOMPSON RACE PARACHUTE & HARDWARE INSTALLED (NEW) 10 POINT NHRA ROLL CAGE/5 POINT RACE HARNESS TRAILER: FULLY LIGHTED 20' /5,000 LB WINCH/LOCKING CABINETS WITH BAR ACROSS/NEW TIRES (4) ANY QUESTIONS OR NEED PICS CONTACT: CONNIEINPALACE@AOL.COM LOTS OF NEW PICS JUST TAKEN BUT ON MY COMPUTER
06-05-2013, 01:54 PM | #2 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
NNNOOOOOOOOOO!!!!!
06-05-2013, 02:29 PM | #3 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Here are some pictures of this beautiful Fast car. Someone is going to get a great Camaro
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi Last edited by MANNYS2SS/RS; 06-05-2013 at 02:40 PM. |
06-05-2013, 03:08 PM | #4 |
Drives: Chevrolets Join Date: May 2013
I don't see an asking price, what are you looking to get out of it?
06-05-2013, 03:55 PM | #5 |
Drives: Varies Join Date: Dec 2009
That's an AMAZING Camaro!!!
Someone is going to get a BEAST!! JT |
06-05-2013, 08:51 PM | #6 |
G200 Pilot
IT"s
06-05-2013, 09:21 PM | #7 |
G200 Pilot
Yup! Have caught severe C7 2014 Vert fever... Bad...
06-06-2013, 08:48 PM | #8 |
That car is one of the best engineered out there. And I bet it could not be duplicated for that price.
06-06-2013, 11:56 PM | #9 |
SoCal HT5 (COTW:12/26/11)
Drives: 2011 Inferno Orange 2SS Join Date: Jul 2010
06-07-2013, 01:08 AM | #10 |
It's not just a hobby!
Drives: 2010 2SS/RS Join Date: Apr 2010
Great build! GLWS!
06-09-2013, 09:12 AM | #11 |
Bump for a great seller with an awesome car
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
06-14-2013, 02:56 PM | #12 |
