10-11-2018, 09:10 AM | #1 |
Drives: 2017 Camaro Join Date: May 2016
Hero Sequential taillights and DEAD BATTERIES
Put on Hero Taillights an my battery went dead in 3 weeks, recharged and it wouldn't hold charge. Dealer checked and said battery and alt. were fine.
Here is the kicker: Two of my Camaro owner friends have had the exact same problem after they installed the Hero Tail lights. Usually shows up as hard starting. IS ANYONE HAVING BATTERY PROBLEMS AFTER THE INSTALL OF THESE HERO TAIL LIGHTS??? Jamesgn |
10-11-2018, 09:24 AM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Sorry to hear. But that's the chance you take trying to saving money w/ cheap Chinese goods. I'd only consider the lights made by GM.
10-11-2018, 09:24 AM | #3 |
Drives: 2017 Camaro 2SS Coupe Join Date: May 2010
Are those the tail lights that look like penors?
10-11-2018, 11:31 AM | #4 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I'm interested in this also. I haven't had a dead battery yet but it has gotten low and had problems starting. Barely turning over fast enough to fire. Dealer says the battery and charging system is good. Here's what we're talking about.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
10-11-2018, 11:34 AM | #5 |
Drives: 2018 Camaro 1SS Silver Ice Metallic Join Date: May 2018
10-11-2018, 12:37 PM | #6 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
ZL1 1LE tails would fix the janky aftermarket light issue
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
10-11-2018, 02:40 PM | #7 |
10-11-2018, 03:46 PM | #8 |
Drives: 2011 Camaro SS Join Date: Apr 2013
Sounds similar to the battery drain on Technostalgia sequential lights for the 5th gen that others complained about for years. My set finally died after 6 years.
The reason for this is that unlike a the stock lamp where a bulb is simply on or off, sequential lamps like these intercept the turn signal and run it through a buttload of timer chips, capacitors, and other circuitry to create a sweeping effect. Even if the lamps are "made in America", you can bet they are cranking out the circuit boards in China and probably cutting corners by not using the optimal circuit design to avoid issues like parasitic drain where they suck power even when "off." The only solution is to get a battery tender or just install a kill switch somewhere to cut power to the lamps when you park for extended periods. A kill switch is probably better in the long term because if there's parasitic drain, it means some of those components in the lamps are going to be under constant load, meaning more chances for something to go wrong over time. In my case, my lamps died when my car was connected to a battery tender when the car was in storage for a few months.
Disclaimer: Unless specific sources are cited, all of the above is my subjective opinion. No warranties, expressed or implied, are granted. This is a car forum, after all.
