01-16-2021, 09:25 PM | #1 |
Drives: 2015 camaro SS Join Date: Dec 2018
tuning for high-flow cats
Before you read any further and assume I haven't done any research: I have. I tried searching on here to no great success, and what I have found about the subject makes me nervous. And the search on the forums isn't working on either tapatalk or browser based on laptop.
Here's the situation: Installing new kook's Long tube headers (1-7/8") and getting WB O2 bung welded on this week. (AEM wideband, the one that is sold on HP Tuner's, except I got through summit) headers have regular High flow cats (NOT the Green versions.) I've read it'll throw a code due to the HF cats (Not really that big of a deal, CELs can be disabled) but more importantly, I have read it will make it run lean and will cause the ECM to throw more fuel at it to richen it back up and will cause some weakness on the bottom end. Not going to work for me. I'm not opposed to doing the whole non-fouler trick, but I would really love to tune it properly to where it won't throw a code and it will read the exhaust correctly. Does anyone know what needs to be changed in HPT to make it run correctly? What worked for you? I don't particularly want to pay for a remote tune as I'll be doing a cam swap in the near future (GPI SS2) and I know a lot of remote tuners won't touch anything that has a cam with more than .600 lift (this is .61 something I think) Anyway, any help would be greatly appreciated. Resources are awesome, but I've been struggling to find any info on it (I watch goat rope frequently.) |
01-17-2021, 06:00 AM | #2 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Sorry I can't help you with the HP tuners. Ryan@gpi remote-tuned my SS2 cam. His attention to detail and quick revisions was great. We did 6 revisions until it was exactly where he wanted it. Also if you purchase their remote to now, in the future when you go to do your cam it would be $100 to retune.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
01-17-2021, 10:59 AM | #3 | |
01-27-2021, 08:55 AM | #4 | |
www.jannettyracing.com
02-03-2021, 03:25 PM | #5 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
In simplest overview terms:
- recalibrate the airflow model / transfer functions in closed loop (get fuel trims closer to nominal) - recalibrate airflow in open loop PE to hit desired WOT fueling (prevent the lean condition I assume you are speaking about) - deal with the relevant codes (prevent the CEL) That's about it for headers only. Might be able to throw more timing at it too, but need a dyno or track to do that safely and accurately.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
02-04-2021, 08:10 AM | #6 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Pretty much you turn the CEL off from reporting and then correct the a/f ratio, which you need to do anyway with the headers.
The headers would force the lean condition more than the HF cat. The cat would just throw the CEL and have you fail emissions testing.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
02-05-2021, 06:36 AM | #7 | ||
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Once you get your cam installed, I would highly suggest Ted Jannetty for remote tuning. I've hired him twice (2 different setups) and we made 27 total revisions to get things perfect. Not only does he tune the car, but he can see mechanical problems in the logs. For example he could tell I had a small misfire, which led me to find a slightly cracked plug. He also knew I needed a second bypass, cause too much air was flowing across the maf at part throttle. He will guide you through your mechanical mishaps... that's priceless. He's not the cheapest, but you'll see why. Quote:
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-06-2021, 07:26 AM | #8 | |
