Old 03-04-2012, 06:57 PM   #57
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
A 2" almost is too big for the knuckle but works as long as you line it up straight
MileMAN402 is offline   Reply With Quote
Old 03-04-2012, 07:07 PM   #58
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Originally Posted by njdad61 View Post
Since there wasn't enough room to get a ratchet and deep well socket on the nut because of the rotor guard, you have to have enough washers to keep the nut from going too far to hold it with a wrench. I'm sure a 2" hole saw would work, I just saw in PQ's video that he used a 1 7/8" and it fit perfectly around the bushing.
Figures that after writing it lol. Can't wait to start work on it on wednesday!!!
Caswell239 is offline   Reply With Quote
Old 03-11-2012, 02:28 PM   #59
STL_G8GT
Drives: 2009 Pontiac G8 GT
Originally Posted by ssmike View Post
Disregard, I got it! No need to remove anything! It was a tight fit but they came out like butta!
Used your method today on my G8... made it SIMPLE... before this I was killing myself trying to figure it out. Thank you for posting this!
2009 PBM G8 GT
Pat G Non-DoD Cam, ARP Bits, DSteck/Shane Tuned, Magnacharger Chrome 2300 1:1, RCR Ported/Polished TB, Blower, & L92 Heads w/ LS3 intake valves, Comp Cams Trunion Upgrade Kit, ARH 1 7/8 catted to Hooker Maxflows, RotoFab, CTS-V PWM 1:1 fuel system, ID850 injectors
Mike Norris Motorsports Catchcan, AEM 30-4100, JHP Boost/Fuel Gauge Pod
TSW Nurburgring Matte Gray 18" w/Nitto 555 & 555R, Satin Black SS Brembo Fronts, BMR Trailing Arms, Pedders Sway Bars, Whiteline Bushings
STL_G8GT is offline   Reply With Quote
Old 03-11-2012, 02:32 PM   #60
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
I tried but it just broke threw the hole saw, ended up just undoing the lower control arm bolt and lifting the bracket up to get a ball joint press on it
Old 03-11-2012, 06:47 PM   #61
MileMAN402
RIP JoePa
MileMAN402's Avatar
Hmm did you use a high quality hole saw? My hole saw didn't even bend, only the washer behind it.
Old 03-11-2012, 08:08 PM   #62
STL_G8GT
I used the pulley puller... worked perfect!
2009 PBM G8 GT
Old 03-11-2012, 08:40 PM   #63
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Excellent! Glad to help a G8 friend!
ssmike is offline   Reply With Quote
Old 03-18-2012, 04:04 PM   #64
Fraxum
Fraxum's Avatar
Mustang drag challenge
I bought a small gear puller since any project is good excuse to buy a new tool. Thanks OP for the idea. Then I buy my outer TA bushings from Apex Chase. Great service bythe way. Then on a pleasant Sunday afternoon I decide to do the deed.
So I pull the driver's side tire and carefully set up the jack stand. (I hate jack stands.) I get the outer TA nut off (its on the side facing the front of the car) and carefull tap out the outer TA bolt.
BUT head of the bolt hits the stock lower control arm before it comes all the way out. I try putting a load on the axle with the floor jack but no help. So I put the whole thing back together. I see no way to do this without lowering the LCA too. Is this needed? Or am I doing something wrong?
My local Camaro club has a Mustang challenge coming up at the drags and I still have wheelhop. How will I represent?
Old 03-18-2012, 04:11 PM   #65
ssmike
BL1ZZRD
ssmike's Avatar
Same thing happened to me on the driver side. I had to unbolt the lower control arm and pry it out of the way. No biggy, only took an additional 1/2 hour. Wierd thing is that the passenger side bolt just cleared and I didn't have to remove the LCA! Go ahead and do the deed before the challenge!
Old 03-18-2012, 09:42 PM   #66
Fraxum
Fraxum's Avatar
Thanks. I was just worried this would force me into a wheel alignment. I wanted to to that once after replacing some of the front bushings.
Old 03-19-2012, 01:46 AM   #67
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Sorry I forgot to take pictures, but this what I used to get mine out:
All of this is from Lowe's Hardware Department
6" Full Threaded Bolt - Thread Size 3/8-16 (buy 2 in case the threads get chewed up.)
Grade 8 Nuts - 3/8-16 (buy 4 or 5)
Grade 8 Washers - 3/8 (buy enough to be able to push the bushing out. Around 10 should be good.)
1 7/8" Hole Saw - (like in PQ's video. I got one made for metal so the teeth dug in to keep it from turning. Just left a few minor scratches)
9/16 Wrench and 9/16 Socket or Ratcheting Wrench to turn/hold the bolt/nut.
that's how i did mine. i used a socket just a little biger then the bushing.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 03-19-2012, 01:57 PM   #68
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Here is another illustration that may help you guys with some ideas on how to remove that bushing. It's really not too tricky with the proper tools, and definitely worth the time to replace the factory rubber bushing!
PfadtRacing is offline   Reply With Quote
Old 07-23-2021, 07:39 PM   #69
BlackBettySS_
Drives: 2010 Camaro SS
What’s this tool called? I’ve been trying to find it
BlackBettySS_ is offline   Reply With Quote
Pfadt Trailing Arm Install Help Agent WD-40 Suspension / Brakes / Chassis 13 07-12-2011 05:23 PM
PFADT Rear Control Arm and Trailing Arm Alignment NVMYSS Suspension / Brakes / Chassis 6 05-20-2011 11:16 AM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing LMPerformance V8 Bolt-Ons & Tunes 3 10-19-2009 03:33 PM
98 camaro z28 torque arm removal boxmonkeyracing 4th Generation Camaros 5 06-13-2008 08:02 PM
