06-14-2022, 09:33 AM | #15 |
Drives: 2017 2LT RS Join Date: Nov 2018
06-14-2022, 05:29 PM | #16 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I have the AAWireless in my car and it works beautifully. Try using the app to change some of the settings (while the device is plugged in to either USB port in your center console). Try changing one setting at a time, beginning with pass through mode. I'm pretty confident you will get it to work, as long as you didn't receive a defective device. Also, make sure you update to the latest firmware.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
06-14-2022, 11:24 PM | #17 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Thank you guys. I've done everything you described, I have even contacted their customer service and I followed their instructions to the letter. It just doesn't connect. I don't know if it's a defective device or not and I am into high tech stuff, so I believe the issue is not on my end. I even tried 3 different USB cables that I know are of good quality and that I use to connect my phone to the car. Same issue with each one of them, this damn thing doesn't want to connect!
Mosaic black 2018 Camaro 2SS A8 (sold) |
06-15-2022, 03:49 AM | #18 |
Makis
Update: After trying to address the connection issue with their customer support, they decided to send me a new device as this one seems to be defective. I hope the new one will be able to connect
06-15-2022, 06:14 AM | #19 |
Good luck with the new device
I had intermittent connection issues with my early bird unit that required unplugging and reconnecting the device (to quickly make it reboot), but the latest firmware solved everything, it now works 100% of the time, regardless of cold/warm start, where the car is in the component shutdown sequence and bluetooth/wifi enable combinations on the phone. It's truly fire and forget now, your new unit will have to work. Initial setup may still be flaky, but once it manages to connect, you'll be golden.
06-15-2022, 07:19 AM | #20 |
Makis
Thanks for the input Arpad. I really hope so. This is a cool device and I need to get rid of the USB cables asap!
07-10-2022, 11:13 AM | #21 | |
Howdy! Pete here...
It's gotten to the point where I don't even think about it anymore. I just get in the car and drive. It boots up Android Auto before I've finished backing out of the garage. I can't even remember the last time it glitched on me. It just works. Now I only plug my phone in in my car if it needs to charge. I have a separate USB-C cable plugged in and out of sight for the rare occasion that I need to charge in the car, or for long trips where I will definitely need to charge from time to time. No more over-charging my phone. Quick, seamless, wireless connection to Android Auto. Just get it...you won't regret it. I also have the Ottocast U2-X. I bought it for my wife's car because she uses an iPhone and I use an Android. The U2-X supports both Apple Carplay and Android Auto. This unit is also getting better with firmware updates, but is still a little iffy at times. The audio doesn't always return properly to the headunit after playing back a text or after a phone call. But a quick un-plug/re-plug always takes care of it. It also boots up very quickly (almost as fast as the AAWireless). It's a bit more of an ordeal to upgrade the firmware on the U2-X because there is no companion app, but it's not that complicated if you follow the instructions provided. Pretty happy with both of them actually.
PnCRedJwl2SS
07-10-2022, 11:24 AM | #22 | |
Howdy! Pete here...
Post an update when you get a chance. Hope its working for you now
PnCRedJwl2SS
07-11-2022, 01:33 AM | #23 |
Makis
Thanks. There was a security update a couple of days ago, so maybe you are right. I will try it again when I return from my vacation.
09-20-2022, 05:26 AM | #24 |
Makis
Just an update that I forgot to post earlier for other users of the AA Wireless device. It seems that it was actually a Galaxy S22 issue. Samsung pushed a couple of updates and afterwards I managed to setup the device almost instantly. It now works flawlessly. As Arpad and PnCRedJwl2SS said above, I just get in the car and I forget that it's even there, as it connects almost instantly.
One piece of advice: I keep mine in the wireless charger behind the front seats on long trips, to avoid battery discharge (I 've modified the charging pad and the S22 fits perfectly). Great device indeed! For those interested, the photos below show how I modified the charging pad.
Tags |
aawireless, android, androidauto, dongle, wireless |
