Drives: 2016 2SS Join Date: Mar 2014
Clutch warantee
I assume the clutch is classified as a wear item and not covered under warranty?
Probably
![]() Drives: 2016 Camaro 1SS Join Date: Jun 2016
in the bumper to bumper and i can assume the powertrain as well
2016 Camaro 1SS
1983 Camaro Z28 1967 Ford Galaxie police interceptor 2006 Honda Shadow |
#4 | |
I launched the car in comp mode at 4k feathering the clutch and it flew like a bat out of hell! However the car is in my garage and I can smell the clutch. Not sure if the smell is on my clothes or if it is actually coming in from the garage but either way doing that every once in a while is definitely going to lessen the life of the clutch. If it is covered under warranty I may use that method on special occasions, if not that is the last time. |
![]() ![]() Drives: 2016/SS Has had 4 Gen 5's Join Date: Dec 2015
12,000 miles is what I was told on my 2013 Gen 5..
SnoWhite |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
That depends, how many more of those launches you have planned?
![]() It really depends on how you drive it. Assuming your are easy on it and don't ride the clutch then probably 100k miles but if you abuse it then you could get anywhere from 30-50k miles. It is like asking how long do brake pads last. It depends.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
Spoke with my dealer regarding this as well. They mentioned that if you have problems under 12k miles, they should replace it.. But they also mentioned that if it's been abused, not defects from factory then it won't be covered.
Not too sure how can they determine if it's been abused or a defect since I'm not a clutch expert. |
#9 | |
#10 | |
Ill do it one more time to see if it is actually faster than 0-60 or if the risk and noise makes it feel faster. After that I'll stick to my normal launches. |
#11 |
Separate question:
How much does it cost to replace a clutch with parts, labor etc? Around a grand sound right? |
#12 |
![]() Drives: 2018 ZL1 1LE Join Date: Jul 2009
The dealer has to replace my clutch pedal assembly. There is a clicking noise about an inch into the pedal travel and also when it reaches the floor. No reason why, just said it had to be replaced. Really hoping they don't have to remove the dash.
#13 |
Sounds about right. The oem parts are usually around 400-500 plus labor.
#14 |
It is the having no mufflers at 4k rpm that makes it seem faster. I tried launch control again and best I could do is 4.2, I'm definitely faster doing my own launch.
